Another MX6 Brush Hog Failure
   / Another MX6 Brush Hog Failure #1
scottbjd
John Deere 4520
I've seen several posts regarding this issue and wasn't sure where to post - so I just threw it in here.
Just wanted to chime in and let folks know I own a MX6 Brushog, a year or two old, and a few days ago the main shaft busted in two and the stump jumper and blades fell out of the bottom of the bush hog. I am presently arguing with my local dealer as to how to get it repaired as they are claiming John Deere is not willing to fix it for free. About a $1600.00 repair!
   / Another MX6 Brush Hog Failure #2
I also own one in the danger zone, but so far no problems. What were you cutting when it broke?
   / Another MX6 Brush Hog Failure #3
Is it a certain year MX6 or all years in danger? I can only see a partial serial number on mine and I bought it used in 2008.
Larry
   / Another MX6 Brush Hog Failure #4
scott
:welcome:
We don't know much about why or how it broke. And likely the Deere dealer doesn't either.
Can you cross reference or link to the other similar failures?
Also, some interest in what you were brush hogging, as well as what tractor you were using would be helpful to know.
Looking for a way to be sympathetic to your dilema. That is a big hunk 'o change.
   / Another MX6 Brush Hog Failure #5
I know of a case where a man borrowed an MX6 last year to bushog a deer field and he said he noticed a change in the tractor's rpm and looked back to see the stump jumper and blades on the ground. It is my understanding the local John Deere dealer helped them with the cost of repair, but I don't know any details.
Larry
Tractor is a JD 4520.
I was cutting 8" tall GRASS when the bottom fell out (just like deere36 story)
This is my first (well, second) post on this forum, I don't know my way around, but I will try to find cross posts.
We had some balance problems from the start with this cutter - went back to the dealer twice. When I called him about the recent problem service manager aknowledged that they were aware of this issue, there were problems with certain serial numbers (bad steel shafts), assurred me it was "probably" a defect, and not a problem. They came and got it, and then called back to say it did not "fall within those bad serial numbers".
Now, of course, I don't have it on hand to tell you if it was chinese or spanish, or what the serial number was. I understand it was the units made in spain that had trouble.
This Bushog HAS had some use. Hit some rocks etc - has several 1/2" dents in the cover from rocks (we are in the ozarks; there is more rock than soil). But the day the bottom fell out I was mowing grass. I backed up, went forward and saw the stump jumper laying on the ground. No noise, no bang, no hit. The shaft looks broken exactly like the one pictured in the other post (I'll try to find it).
@Greasemonkey: You mentioned you have one in the "danger zone". What is the "dangerzone"? Do you know the range of bad serial numbers?
   / Another MX6 Brush Hog Failure #8
I also have a 4520 Power reverser with MX6 rotory mower.And live in the Ozarks. And used the rotary mower for a good deal of clearing the brush on 30 acres of dozer cleared land after a tornado. Then in reading some of the former posts asked my J.D. Dealer about this problem he assured me only some had the shaft that was defective. Decided to park the thing. attach to a 20 year old bush hog that has had the gear box rebuilt and all the dings rewelded then went back to clearing brush with the knowledge I will not have a problem that costs more than a new bush hog brand of a rotary cutter.. John Deere wasn't smart in allowing this kind of negitive advertisement.
ken
   / Another MX6 Brush Hog Failure #9
Have any photos of the failure point?
   / Another MX6 Brush Hog Failure #11
Add me to this list. I was using my 4710 And MX-6 cutting nothing more then tall field grass and heard the RPM shoot up. Yanked the tractor to idle, looked behind me and saw the stump pan and blades lying behind me. The main shaft sheared right in two. Clutch discs were fine and not frozen. I assumed I could replace one or both of the planetary gears in the gearbox but found that was not to be. Seems John Deere changed the ENTIRE setup on this mower and now you can only buy complete replacement gearbox on down. Cost about $1600. Gee......I wonder why John Deere changed the entire gearbox if they had no problems with the old style??
Sorry to hear that. It took some pressure and a letter and a couple phone calls to the dealer and the John Deere Main Office, but the dealer DID (after several months and the purchase of another Bush Hog), finally end up fixing the Bush Hog without charge in my case. They never admitted it was faulty, and passed it off to "good customer relations".
You didn't mention how old yours was... If it's not too old it would probably be worth a shot. Whether they want to admit a defect or not, it will cost them more than the cost of repair to meet you in court...
   / Another MX6 Brush Hog Failure #13
These are a black eye for JD....... too bad they aren't just making everyone whole who has had one break. I saw another one on CL recently, same deal. It was otherwise in great condition, and the seller was only asking $300...... but with the price of a new gearbox.......... :confused2:
   / Another MX6 Brush Hog Failure #14
I bought my tractor and implements in 2004 and this happened Summer of 2010. Six year old brush hog should not be breaking like that. Especially when you add up the total number of hours the unit operated. I don't know an exact number but to cut my field twice a year for six years plus some miscellaneous extra cutting does not add up to more then 100 to 150 hours. Let's be crazy and say 300 hours TOPS.....at more then $3000 purchase price that's a lot of $$ per hour for a dead and worthless piece of equipment. I asked once at my dealership but reading these posts gives me some new motivation to start again. Does anybody have any stats on how many units we know about here on TByNet?
   / Another MX6 Brush Hog Failure #16
Man i just found this thread. My friend and i had this exact problem. We were mowing a food plot of clover and the tractor sounded different so we stopped and walked behind the tractor only to find the blades. Apparently the shaft broke and took over $1000 to repair it. Cutter only had about 70 hours on it but since it was just over 5 years old they would not warrenty it. The funny thing is we only mow grass and light brush with it. Hopefully the new parts are better than the original ones.
   / Another MX6 Brush Hog Failure #17
   / Another MX6 Brush Hog Failure #18
   / Another MX6 Brush Hog Failure #19
I wonder when someone is going to bring a class action suit against them. I have one but it not broke yet.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
