Antifreeze- is any type OK?
   / Antifreeze- is any type OK? #51
At least with your 'condensed' water.. lotsa the minerals stayed on the coils.. I'm sure the battery likes it rather than hard tap water from a well.. etc.
soundguy
   / Antifreeze- is any type OK? #52
My father used to collect rain water and save it in gallon jugs, we used it to fill all our batteries.
   / Antifreeze- is any type OK? #53
I know pwople that still do that for batts and rads..
soundguy
   / Antifreeze- is any type OK? #54
The CNh addative also has the added benefit of an electrolysys addative, besides the anti cavitation.
You can get the cheap bottle and swizzle sticks right at the counter.
soundguy
Soundguy
What antifreeze brand /type would you recomend I run in my NH tc45A? I plan on obtaining the CNH additives you recomend as well.
Thanks
   / Antifreeze- is any type OK? #55
I like to use a fleet diesel AF, and i add the conditioners from NH. My dealer told me 'plain gree' AF plus the conditioner was fine.. but I opt for the slightly more expensive stuff for that warm fuzzy feeling.
soundguy
   / Antifreeze- is any type OK? #56
soundguy
Thanks. Another poster above said the cavitation was only a problem when running an engine with sleeves but I will run the conditioner regardless.
   / Antifreeze- is any type OK? #57
In addition to anti-cavitation addatives, the conditioner also helps prevent electrolysis.
soundguy
   / Antifreeze- is any type OK? #58
And controls the pH level.
   / Antifreeze- is any type OK? #59
Yep.. and it's cheap too.. only about 5$ down here in florida...
soundguy
   / Antifreeze- is any type OK? #60
A heck of a lot cheaper than a engine overhaul or worse.
2017 Dodge Ram SLT (A57024)
2017 Dodge Ram SLT...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
MISC TOOLS (A55745)
MISC TOOLS (A55745)
SCAN TO RECEIVE TEXT UPDATES (A52707)
SCAN TO RECEIVE...
