any downside to hst?
   / any downside to hst? #101
We've seemed to drift off-topic, so I'll throw this out for discussion-
Has anyone ever tried to pull-start a HST tractor?
I've pull-started an automobile with automatic transmission.
In respect to battery failure (or disappearance), will the new "gear" tractors with electric PTO, digital guages, safety switches, etc. operate without a good source of battery power?
   / any downside to hst? #102
I wholeheartedly agree. If I did anything more than incedental loader work.. i think an upgrade to a plain gear tranny would be in order.
Soundguy
3RRL said:
Soundguy,
You'd be dead broke BECAUSE you're be divorced.:D
I've got a gear tranny and it's OK to do a lot of shifting for fun. But man, when you start doing some serious loader work clutching every few seconds for hours at a time becomes a real drag. .
   / any downside to hst? #103
>In respect to battery failure (or disappearance), will the new "gear" tractors >with electric PTO, digital guages, safety switches, etc. operate without a >good source of battery power
In many cases.. I'd guess you would need a battery on the cables.. but it could be your pickup battery.. Even if your truck battery won't get the cat 3208 started... it will be a fine load for the alternator on the machine, and should make the electronics happy.
Older diesels with lo/no electronics and gennies will be more tolerant of a missing battery.
Low batteries needing to be charged shouldn't be an issue.. unless they have bad cells.
Pullstart an HST.??? Hmmm... My first thought would be no.. but then.. I've never tried to pull start a small HST tractor. I know you can't pull start construction equipment that has hyd/hst/auto trans.
Soundguy
   / any downside to hst? #104
MossRoad said:
If I were going to pick a tranny on it's ability to be pull started, I would have to wonder how often the tractor is going to fail and if it is a dependable unit.:cool:
I've jump started very large detroit diesels that ran huge compressors(something like 1200CFM @ 40PSI) to huff start massive turboprop and jet engines on airliners, so, I figured it would work on a tractor. :eek: Remove the open battery from the circuit(or batteries, as ours were four 6V in series/parallel) and start it off the jumper vehicle. Once it is running, disconnect the jumpers and off you go. The battery cables were no larger than our jumper cables, so I don't see why they wouldn't work. Perhaps you are thinking of jumping it off a car battery and I am thinking something larger, like a tractor battery. We jumped truck to truck, so maybe your jumper vehicle had a small battery compared to your tractors? I frequently jump started my 50PTO hp IH off of my pickup truck with no problems. I did have a huge battery in it, though.
Pretty much, yes the 5000 had the biggest battery on the farm except fot the D6 (which was on the other side of the farm) . But the battery was not just dead it was open, a bit worse to jump.
My point is that on a gear tranny diesel you can roll or pull start them as a last resort option, you don't have that option on hydro tranny tractor. Your starter or solenoid go out and you are just down. Or in our case the battery went open.
So we just put the truck battery in there to run the string tie mechanism on the bailer and pull started it. The truck battey was just too small to even turn the engine over.
We did get a new battery on Monday when the CNH dealer opened, and all is well now :)
   / any downside to hst? #105
NoMo said:
...Has anyone ever tried to pull-start a HST tractor? ...
No. My old IH specifically said not to pull it with the engine off. Well, it didn't say it, of course... tractors can't talk. But the operators manual had a section on towing the unit. You had to put the range selcetor in neutral and add several gallons of fluid to the tranny. Then I think you had to manipulate a valve on the case somewhere, but I could be mistaken. After you towed it to where you were going, you had to drain the tranny back down to the proper level, maniplate the valve again, etc....
My current Power Trac is different in design in that I don't have a tranny at all, just a variable volume pump that supplies fluid to four hydraulic motors, one at each wheel. On that pump, you have to open a bypass valve to tow it or you will damage the pump. So I'd assume that you can't pull start it, either.
   / any downside to hst? #106
Don't believe pull starting a tractor will be the reason for me selecting a tractor. I want ease of operation. I am seriously looking at HST.
   / any downside to hst? #107
I don't think any -single- feature should solely determine what tractor you buy.. unless it is simply a 'must' have feature, reguardless of all other criteria.
Soundguy
   / any downside to hst? #108
:Speaking from the perspective of a guy with electrical problems involving door locks and a sunroof, I have to agree with that. It's also pretty typical of the dilemma folks face when buying anything, including internet use.
You can get the easier/faster/better more expensive version, like my wireless broadband or you go with the older/slower cheaper version, like my dialup. I like the broadband much better, WHEN IT WORKS. Living where I do, it's about 85% reliable normally, about 25% if it's raining. The dialup is always there but agonizingly slow by comparison. Sometimes I like the dialup, sometimes the broadband.
Maybe we all need several tractors each with a different type of tranny.:)
   / any downside to hst? #109
Soundguy
Agreed, the topic was looking for any downsides to HST though.
   / any downside to hst? #110
Agreed. That is why I like the older simpler tractors better. KISS.
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2017 Ford F-250 Service Truck (A55852)
2017 Ford F-250...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
