NoMo
Talking tractors- they probably aren't too far off in the future.MossRoad said:No. My old IH specifically said not to pull it with the engine off. Well, it didn't say it, of course... tractors can't talk. But the operators manual had a section on towing the unit. You had to put the range selcetor in neutral and add several gallons of fluid to the tranny. Then I think you had to manipulate a valve on the case somewhere, but I could be mistaken. After you towed it to where you were going, you had to drain the tranny back down to the proper level, maniplate the valve again, etc....
It's pretty interesting reading about all of the HST variations available.
My JD manual indicates that towing the machine for "short distances" is OK... but only at 10MPH or less. No special procedure other than the common-sense stuff of tranny in neutral, PTO & parking brake off, etc.
