Any Electricians out there?
   / Any Electricians out there? #11
Make sure you turn the breaker all the way off, then on again.
Do you have a GFCI outlet?
Odds are very bad that a normal outlet will go bad, and even harder to believe that an entire line will be affected. Outlets are connected in line, so the first one, or closest one to the breaker would be the bad one if it's bad. If the breaker is on and good, then you will have power to the wire going into the first outlet box. Take off the faceplate and check for power at the wire.
Breakers go bad, so if the first outlet is not a GFCI, and you turned the breaker all the way off, then on again and still don't have power, replacing the breaker would be my next step. I had this happen on a breaker going to a water heater a few years ago. It worked great for years, then just quit, leaving me with cold water and no power to the water heater.
   / Any Electricians out there? #12
Is the shop wired for 230 volts? did you lose one leg? Time to break out the meter, take 10 seconds to determine the problem.
Back to my pet peeve. Why oh Why don't we take a couple of days in our educational system in 8th or 9th grade science and devote just 2 or 3 days of theory and lab work to teaching people basic electricity?
I know, I know.. I rant and rave, about a lot of stuff... sorry..:eek:
..and devote some time to basic personal finance. Like why making the minimum credit card payment on a $50 dollar pair of jeans at 20% interest makes the purchase price hundreds of dollars for pants that are worth $5 (resale) the moment you walk out the store.
   / Any Electricians out there? #13
This happened in my garage. Outlets on west and south wall quit working.........GFCI outlet was bad. Replaced it and everything was fine.
   / Any Electricians out there? #14
This happened in my garage. Outlets on west and south wall quit working.........GFCI outlet (first one in line after the panel) was bad. Replaced it and everything was fine.
   / Any Electricians out there? #15
I've seen outlets fail (especially the cheap ones). That's why best practice is not to use the outlet as the junction for the next "fixture" in the chain. As for breakers, it's rare but does happen. I always keep a few spares (20 and 15 amps) on hand for failure or for future circuits...I used the Square D "Homeline" panel and they aren't that expensive (I store them inside the panel).
   / Any Electricians out there? #16
GFCI's are known to fail and in order to maintain GFCI protection "downstream" you have to use the outlet as the junction. They aren't cheap anymore after that tamper resistant nonsense but doesn't hurt to have a spare or 2 on hand.
Thanks everyone, but like I said...I have eight years of college...math, science and the law...and 50 years experience, but I am no electrician. I wouldn't know a GFCI from a UFO. I can tell you that the line to the shop was run from the house in an underground cable, and I have a 220 outlet because I thought I might want an AC or use a welder. The plug-ins (junction boxes?) are all industrial quality and not the cheap plastic stuff you find in a house. I have an off/on switch at the house.
There are two lines in the shop; one goes to the overhead lights and the North side of the shop, the other goes to the South side...and that gentlemen is the extent of my knowledge. Should I make up a double male ended extension cord and run it from North to the South? (Just kidding! I did see a PhD Chemist try this in the laboratory that I worked in...don't know how he made out; the safety committee cut him off at the knees). I do know some folks who know about electromotricity, guess I better just call one of them. I hate being shocked as much as finding a spider crawling on my neck.
   / Any Electricians out there? #18
Buy a cheap meter. Watch a couple of youtube videos on how to use it. Make sure breaker is on. Start at the breaker terminals where the wires connect to the breaker and work downstream from there. You can easily handle this and will feel good knowing you learned something new.
Thanks for the advice. I'll check it out. I did build an electric motor from enameled wire, nails and block of wood, for my Senior Science project.
   / Any Electricians out there? #20
I think that if you don't know or cant tell the difference between a GFCI receptacle and a regular one, then maybe you should call an electrician or get a buddy over that knows a bit about electrical problems. This would be a safer alternative than trying to troubleshoot something on it yourself.
72In FEL HD Round Back Bucket (A52128)
72In FEL HD Round...
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
(3) RYOBI POWERED BRUSHLESS PUSH MOWERS (A51244)
(3) RYOBI POWERED...
Kubota RTV500 (A47384)
Shopbuilt Snow Plow (A50515)
Shopbuilt Snow...
