Mace Canute
Elite Member
Thanks everyone, but like I said...I have eight years of college...math, science and the law...and 50 years experience, but I am no electrician. I wouldn't know a GFCI from a UFO. I can tell you that the line to the shop was run from the house in an underground cable, and I have a 220 outlet because I thought I might want an AC or use a welder. The plug-ins (junction boxes?) are all industrial quality and not the cheap plastic stuff you find in a house. I have an off/on switch at the house.
There are two lines in the shop; one goes to the overhead lights and the North side of the shop, the other goes to the South side...and that gentlemen is the extent of my knowledge. Should I make up a double male ended extension cord and run it from North to the South? (Just kidding! I did see a PhD Chemist try this in the laboratory that I worked in...don't know how he made out; the safety committee cut him off at the knees). I do know some folks who know about electromotricity, guess I better just call one of them. I hate being shocked as much as finding a spider crawling on my neck.
Start at the source and check for voltage on each hot leg. Every time you come to a switch or breaker check both the line and load sides of it. Good ones will show voltage both sides (when in the on position of course) while a failed on will only show voltage on the line side when in the on position.
Sometimes the breaker contact will become oxidized and corroded and will fail but will reconnect after several off/on cycles because of a built in wiping action. If this happens it's still bad but might get you by a short bit of time and will of course need replacing ASAP.
