Any Electricians out there?
   / Any Electricians out there? #51
Quite a few years ago when I had to work in a control panel and I was uncomfortable with do that I would tie a rope around me and have my wife standing by, just in case. But in my defense, that was before we had TBN to get all this good advice. I like the plug in tester first and then start checking with the multimeter. I would maybe check and re-tighten the connections inside the panel making sure the breaker is off in the house. Even the breaker in the house may have a loose wire.
   / Any Electricians out there? #52
I guess you never told your wife about how much life insurance you had. :) But anyway, electricity is one of those things that scares a lot of people. I'll admit that I learned a lot via errors that should have killed me but didn't (e.g. gotta be very careful in the panel box where the neutral/ground bus is usually pretty close the "hot" bars (typical 240v installation means 2 of them). Ruined a screwdriver once but learned a lot about welding in the process. Beyond the panel, no reason to fear anything if you "kill" the main and carry a flashlight. Btw the multimeter can be used to check outlets also but that little plug-in thing is a no-brainer thing and will also test for polarity and ground (and will also test for GFCI connections if the outlet is on one).
   / Any Electricians out there? #53
Not an electician, but an electrical engineer.. I find electric circuits to be rather simple, but you do have to respect what you can't see.
check the breaker output first, then proceed down the circuit. Using a volt meter is really no more dangerous than plugging something into an outlet, just gotta know not to touch the live circuit.
   / Any Electricians out there? #54
We haven't heard from 2Lane aka.....Sparky..... since 7:38 this morning........hope he' has called a friend and/or fixed the problem......I saw on the news there was a power flicker throughout Oklahoma earlier today.........maybe he really did lick his fingers?
   / Any Electricians out there? #55
Well it's very similar. With both you're holding an insulated conductor as it touches other electrified metal.
Just don't let one probe touch two pieces of metal at the same time, especially if one is Hot and the other is grounded (like when testing the terminals of a receptacle and the probe also touches the metal receptacle box). It's not dangerous, but the flash can be startling.
   / Any Electricians out there? #56
And after the arc, and molten metal, you can post pictures in the welding forum!:D
   / Any Electricians out there? #57
Before you start, say the following.
"Hold my beer and watch this"
Anything you do after that will be ok.
   / Any Electricians out there? #58
Hey wasn't Sparky or was it Sparc who started "pallets in the fields"? Strange things happen to those who start messing with things we don't understand. :laughing:
   / Any Electricians out there? #59
Saw a falling star tonight.....no wait......was that 2lane???:confused3:
After looking at some of those internet pictures of the crispy critters who tried to cut into the high voltage lines in order to purloin copper belonging to the Utility Company, I have decided to take a nap and go to the dentist instead. :p
ROLL OFF BOX (A53843)
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2014 PETERBILT 388 (A53843)
2014 PETERBILT 388...
