Any Excavation Professionals Feel Like Giving Advice?
   / Any Excavation Professionals Feel Like Giving Advice? #41
I don’t know why people want to feel special and describe gravel in mostly regional terms. Everyone knows what a washed 3/4 stone is or what 1-3” looks like.
The original poster is in Ohio, so I gave him Ohio stone terms For the topping material. #1,#2 &57s are from national standards
   / Any Excavation Professionals Feel Like Giving Advice? #42
Can we circle back around to any washed rock, of a fairly uniform size, is not going to bond, and form a smooth durable parking surface, by any name.
   / Any Excavation Professionals Feel Like Giving Advice? #43
One guy said he would strip the soil down to clay, use #1 and #2 limestone as a base, then top dress with #57 limestone
No issue with this, other then the topping material; I would definitely want to know either the thickness or spread rate, or total tons/cys he's proposing; maybe the thought is the 57 will get pushed into the larger rock below; but will still aways have a loose top layer
One guy said he would strip the soil down to clay, use geo-textile fabric, use #1 and #2 as a base, then top dress with #57
No issue; but the fabric is intended to bridge soft pumping material (organics/fat wet clays, does its job, but doesn't 100% fix it; note this isn't a rigid pavement, and minor settlement over the years wouldn't be the end of the world); once again, make sure 1 and 2 are proposing similar thickness; I would not go from 6" with no fabric to 4" with fabric;
One guy said he would NOT strip any soil, use asphalt chunks and grindings as a base, the top dress with #57 lime stone
This is an odd one; in that "grindings" wouldn't benefit from a top coat of stone; unless your wanting an astetic. The "chuncks" concern me a bit; but actually millings straight from the roadway do have chuncks, flakes, RPMs, and a bit of everything. My concern with "chuncks" is are we talking basically demo debris? That'd not what you want, unless we are just filling a swampy pit. Again, compare apples to apples on thickness. #3 sounds bad at first, if this is a poorly drained, nasty area, I could see using larger asphalt debris as a stabilizing material, and something smoother on top. It's almost Always best practice to strip organics; but if some cases; IE its a swampy pit, it can be like waking the dead, basically churning up the soap. If the native soils are fairly decent, strip the organics; avoid disturbing more then necessary; and add base.
Ideally, any road/parking area/trail/building pad should be higher then the surrounding area, either by use of swales or by building up. If your fighting high ground water levels; the base will stay wet if the finish grade is equal to surround area; you just create a sump where you excavate.
   / Any Excavation Professionals Feel Like Giving Advice? #44
AS you can tell from most of the responses......stone "terminology" is definitely different state to state. Finally this is an ohio poster so I can relate. So my first reply here is for everyone else....
#1-2's is the largest before going to rip-rap. They are ~3"-5" stone. Roughly the size of your fist.
#4's is also common for a base....they are about golfball sized. 1.5"-2"
#57 is 5-7 sized stone. ~3/4" stone. Like a large marble
#8 is "pea gravel" size. Just limestone not gravel. ~3/8"
All those are washed and uniform in size. IE: no dust
Then there are 304's which is #4 sized to dust. Basically anything and everything that will fall through a #4 screen. So it has 4's, 57's 8's and lots of dust.
411's are anything that will fall through the 57 screen. So same principal of 304's.....just cuts out the larger sizes but still lots of fines and dust.
   / Any Excavation Professionals Feel Like Giving Advice? #45
thanks for this clarification ... like paulsharvey pointed out I would also be interested on the thickness each contractor are planning on using and the cost per cubic yard of each type of material.
   / Any Excavation Professionals Feel Like Giving Advice? #46
Now to the OP......I would choose NONE of those contractors.
I have done alot of driveways. And know others that build driveways as well. The general rule for a solid drive is strip topsoil.....(usually about 6").....then lay down geotek.
Lay down geotek
8" of 1-2's
3-4" of either 304's or 411's. The dust will filter down into the base layer and lock everything together.
Then (if customer chooses) top with a 1" layer of either 57's or 8's. Just depends on what the customer wants. This results in a drive that is ~5-6" higher than existing grade. And the topsoil stripped is spread and leveled/tapered away from the driveway.
Ever see a dumptruck stuck in a 8" layer of 1-2's. I have......they DONT lock together and the slightest wheel slip and they sink.
Same thing with 57's.
You put down 1-2's and then a thick layer of 57's and its gonna be a nightmare. Nothing will lock together and stay that way. It wont pack and wont remain firm.
For a 30x30 pad...If you DIDNT want it leveled.....youd be ~34t of 1-2.....17t of 411's, and about 5t of 57's plus the geo fabric.
IF you want to correct for the elevation and make it a level pad. Do that ALL with 1-2's....then top with 4" of 411's and a thin coat of 57's on top. Use the topsoil stripped to deposit around the stone on the low sides to "back up" the stone and keep it from wanting to push out. And that would probably up the 1-2's to about 60t
Not sure where in ohio you are (distance to quarry plays a part in stone prices). But in my neck of the woods......NOT accounting for level......and striping topsoil and just doing geo + 8" of 1-2's + 4" of 411's + topcoat of 57's I'd price that job at ~$3000
IF I accounted for level I'd be ~$3800
   / Any Excavation Professionals Feel Like Giving Advice? #47
Stone is sold by the ton. And most figure a yard = 1.5 ton.
The guys I have haul for my jobs haul 24-25t at a time.
And most contractors will put markup on the stone. Myself included. I last quoted 1-2's at $32/ton and 304/411 at $29/ton
But it all depends on proximity to quarry, and the relationship you have with someone that hauls it
   / Any Excavation Professionals Feel Like Giving Advice? #48
I am in the process of talking to a few local excavation companies in regards to a project. It's a simple project (they all have said this), but each has their own method of completing the project. I've been wanting to get this project done for a while now, and life keeps on getting in the way so I will be hiring this one out to a professional.
The project is a 30' x 30' gravel parking pad. The area where it will be installed is currently grass and soil. The area slopes approximately 1.5' right to left over the 30' area and 1' front to back over the 30' area.
My question is: is there truly a "right" way to do this?
They all claim that their way is the "best" way.
So, I am seeking an outsider's opinion which method seems the most logical to go about this project.
A couple of questions: How deep and what type of material is the topsoil? What Is the base layer like. What is the soil moisture content and how does the drainage work.
These are questions to ask before any work should began.
On the stone used I have no idea on the local terminology Or availability. That said the base layer should be well graded 3/4 inch crush and definitely not washed. The top layer should be 1/2 inch well graded crushed gravel not washed. Granular material should be laid down so it is well mixed.
The base clay should see some packing with a vibratory sheep foot type packer. The granular material is packed using a vibratory drum roller.
   / Any Excavation Professionals Feel Like Giving Advice? #49
This is how I do a driveway. Topcoat of #57 or #8 not shown but optional. Some people don't like.
   / Any Excavation Professionals Feel Like Giving Advice? #50
i agree but I will say this again … nobody creat base with pure stone regardless of its size … the only time pure stone is used during road construction is when you are 6” in mud and water … then you would put pure stone to get out of the water then put any granular from 0 inch to what ever they call for … in water you can’t put any fine since it will turn to soupe … pure stone is describe as self compacted, therefore is dosent hold any compaction you need fines to be able to achieve any sord of compaction.
I'm not sure who you are trying to convince with this statement, but I would presume that the first two contractors saying to "strip the top soil" also includes leveling the parking pad area, compacting and readying it for stone. Just because the pad area slope a foot in one way or another doesn't mean the whole thing has to be raised up with dirt fill prior to stone - depending on drainage and customer preference of course.
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
Unused Delta Crash...
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
