Any Good Uses for Busted Leaf Springs?
   / Any Good Uses for Busted Leaf Springs? #21
knife or sword.. :)
I used a piece to make a replica roman short sword. did some grinder and file work, then whire wheel over the pitted area.. wrapped the hilt in leather twine anfter grooving out for it.. so it's full tang.. etc.
awesome looking.. and heck.. it's like a 18" metal club :) ( section I used was straight.. )
soundguy
Looks like I'm keeping the spring.
   / Any Good Uses for Busted Leaf Springs? #23
Wives everywhere are shaking their heads at the beauty we see in broken, rusty metal.
   / Any Good Uses for Busted Leaf Springs? #24
that's why we don't throw scrap metal away.. because it's not scrap.. it's just a project waiting to happen... :)
soundguy
   / Any Good Uses for Busted Leaf Springs? #25
strap em into the bottom of crab or shrimp pots make good wieghts
   / Any Good Uses for Busted Leaf Springs? #26
that's what common rocks are fore.. not good knife / quality steel!!
soundguy
   / Any Good Uses for Busted Leaf Springs? #27
I saw a new use today a man had a straight peice of spring and had cut out a notch on his rotary mower blades and welded the springs to. It made a super blade from a softer new blade.
   / Any Good Uses for Busted Leaf Springs? #28
Leaf spring material is a hard steel. I can be used to make all kinds of tools and such. If it were me, I'd keep every piece of it.
I agree! I actually bought a homemade tool many years back at a rummage sale. I offered less than than it was priced at and the woman said "if you can tell me what it is I will let you have it for that". I said "it is a tool for removing shingles from a roof". She said "gee! my husband was a roofer." Got the tool! It was a cut off baseball bat with a piece of leaf spring bolted to it, very effective too!, still have it.
   / Any Good Uses for Busted Leaf Springs? #29
When I was a boilermaker we would fit butt joints of two sheets of steel together with two leaf springs. You would put one in each hand and put the thin end in the joint and you could move the pieces quickly and accurately for a perfect fit. The second person would tack weld the joint as you went. Two guys could go around a large vessel in a very short fitting and tacking it.
   / Any Good Uses for Busted Leaf Springs? #30
I hardly ever throw anything away. I love making tools when I need them.
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Toro z turn (A56859)
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
