Any hydraulic eng. designer's out there?
   / Any hydraulic eng. designer's out there? #32
some things to remember....
Its got a 4" capacity.
And its not a mower.
   / Any hydraulic eng. designer's out there? #34
From what I have read on this thread, I thought the OP was wanting something to cut low hanging branches off tree, not cutting under brush at ground level.
Yeah, I just need to keep the roads/trails open. Got a 8' bush hog for mowing. Chain saw for the bigger stuff. I have a couple of questions in to the Samuri folks and the SS Solutions folks about the "Razor 5' sickle" as to their intended design/use of their cutters.
   / Any hydraulic eng. designer's out there? #36
I did a little looking at the Samuri. Looks like it uses a stator rotor type motor. 3cuin size with 3 gpm oil and only 500psi. Thats only about 20ftlbs of torque and less than 1hp. Not sure how the motor is mounted, gear reduction or belt driven, but the 3 cuin motor with 3 gpm should spin about 230rpms. The sickle bar should be moving pretty fast, but I dont know how those sickle blades will hold up to a lot of limb cutting. Looks to me like something to trim hedges with and not trees. I think something with a little heavier cutter might do pretty well. I havent seen one in person so maybe I am just over thinking it.
   / Any hydraulic eng. designer's out there? #37
google keywords... then clicking up on "images"
hydraulic tree trimmer
hydraulic tree pruner
hydraulic tree clippers
replace hydraulic with "orchard" or "forestry" or "vineyard"
i saw more pictures of circular saw blades. vs anything else.
the only time i saw a sickle mower / hedge trimmer like blade, the details were around 1.5" max and more like 1.25" max branch size.
the circular saw blades. (multi stacked) saw multi notations of 3 to 4" in size. assuming blades are 10" to 12" in diameter. kinda like a regular circular saw blade / table saw blade i am guessing.
some highlights....
Hydraulic Saw | eBay
SL2 Orchard Pruner - RBSM (actually first time seeing were blades are not overlapping)
Collard Mechanical Pruners
http://1080plus.com/vtTf2oAV7Cg.video different from others i have seen
Hydraulic Tree Clippers jaws of life scissors for cutting branches.
http://claussenfarms.com/publicServices.html different style mount for FEL for circular setup.
http://jumaragricola.es/en/tipo/articulated-pre-pruners one of the better setups i saw for actual mounting to front of tractor or perhaps FEL.
http://www.mytractorforum.com/119-h...essories/214889-hydraulic-drive-pole-saw.html (skid steer almost required) for hydrualic chain saw on a boom.
https://www.youtube.com/watch?v=SGCnm_nzASk circle saw blade multi stacked
http://triplebladeandsteel.com/diamond.htm BIG BAD BOY CIRCULAR SAW BLADE! scroll to bottom of page!
http://www.4startools.com/WOTC8-FL-Hydraulic-Tree-Cutter-Tractor-Loader-Mounted-WOTC8-FL.htm another jaws of life / scissor tree trimmer
http://www.tradeindia.com/fp1424591/Tree-Pruner.html huh? what the heck? saw a small handful of cutters like this 3 to 4 circular blades out on arms.
http://www.bdimachinery.net/57.html large size hedge trimmers with simple design.
sites with multi machines / product types for tree trimming.
http://www.officinameccanicabeg.com/en/pruning-machines/pruner-bgp-4000dv.html little overboard on sickle bar style blade!
http://www.orizzontimacchineagricole.it/agricultural-machines/pruning-machines
http://www.rinieri.com/en/78-Trimmers and pruners/92-Trimmers for vineyards/
http://www.lameng.com/products/rini...ry/trimmers-and-pruners/pruners-for-orchards/
http://www.rbsm.me.uk/light-orchard-tree-pruner.html
   / Any hydraulic eng. designer's out there? #38
Hello Gang, I don't have anything special to offer....just saw the call for a hydraulics engineer and read through the postings. Hydraulic design isn't really my strong suit, although I have done little bit of that kind of design - mostly cylinders and linkages - not much on pumps and motors. But reading through this discussion I quickly realized that it was time for me to just sit back and pay attention to what could be gleaned from all the great, weird, and downright odd solutions folks have come up with for trimming. So I've been just sitting back and learning.
What an interesting discussion it is, too! Just about every post or reference starts my thoughts down a different path. Boggen, that's a great list of devices and some very innovative solutions. Makes me proud to part of the fraternity.
rScotty
Thought for the day: Good Luck generally beats Good Planning
   / Any hydraulic eng. designer's out there? #39
some highlights....
Like you, I think a circle saw would make the best setup. While a gang saw with multiple circle blades works very well, I have seen those run, they are kind of expensive for someone just wanting something for personal use. In post 28, I offered up a feebe of a assortment of parts to make a single saw setup. I am sort of suprised no one has taken me up on the offer. With some minimal fabricating, a pto hydraulic pump, and a good hydraulic motor, retip the blade and one could have a pretty good trim saw pretty dang cheap.
Oh if you were closer! I do appreciate your offer:thumbsup:
City of Lakeland (A51691)
City of Lakeland...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
UNUSED FUTURE EXCAVATOR COMPACTION WHEEL (A51244)
UNUSED FUTURE...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
