Any one use a ventless gas stove for heating.???
/ Any one use a ventless gas stove for heating.??? #1
John White
Newark, Oh
Bob Cat Ct335
I am looking for some one who has experience with a vent free gas stove. When I built my own house 8 years ago. I used 6" walls, insulated good, extra insulation in attic. I put in a 95% high efficacy furnace. (In basement) We have heated the first year with the furnace. House was always cold. Furnace ran a lot and gas bill high. We got a fake fireplace heater with a 1500 watt elec heater in it. We have used it for about 6 years. (we actually turn the heater off at night) A little cold in the morning till it warms up. It keeps our living room, kitchen hall way, bath room livable. Not too cold but not quite warm enough. Can't complain a lot on cost. On real cold days when temp drops to around 15, my wife will turn on kitchen burner. When she does laundry or we are in the basement very long, I installed a small vent free fireplace. That will have the basement toasty in no time. As we are getting older we both find ourselves under a blanket when sitting watching tv. I suggested we install a fireplace type vent less gas heater. I don't think it would take a very large one and do away with the 1500 watt elec one (which looks like a fireplace. with the fake burning flame)/ She says gas will leave a residue on things. And afraid of the fumes, and safety concerns. I don't think there would be any problem. I don't want to cut a hole and vent one. When we first moved in about the first two years when we was using the furnace, When the temp would get 15 or lower, the gas meter would freeze up. (I think our gas comes from stripper wells) I would have to go out and reset it. That's when we got the elec. fireplace. I seen the gas man out one day and told him about it and he sent some one out to fix that problem. Any input or experience on the vent free heater?.
/ Any one use a ventless gas stove for heating.??? #2
Based on the web research I did a few years ago, your wife is right. Ventless gas heaters are trouble, found lots of complaints about them causing condensation and leaving residue that's tough to clean up. Hearth.com would be a good place for expert advice though.
/ Any one use a ventless gas stove for heating.??? #3
We have a 15k BTU propane wall model on our sunporch that we used to use quite a bit, but it does put a film on all the windows out there...and if you can see a film on the windows, it's clearly other places you can't see it.....like furniture...and your lungs.
After putting a wood stove insert in the living room fireplace, we almost never use the propane heater anymore, simply crank up the stove and open the french doors to the sunporch some. If it dips below zero, we'll run it some because wife keeps her domestic weeds out there from their summer home on the deck, and she doesn't want it killing off her plants.
/ Any one use a ventless gas stove for heating.??? #4
Those people with working CO detectors have a different opinion about non vented heaters.
/ Any one use a ventless gas stove for heating.??? #5
We have one in our basement. Here are my thoughts. Yes there is a film on things, notably the windows and ceiling lamps. But it takes some time to notice it. The mother in law lived in the basement for the past 8 years and used it a supplemental heat. She never liked the temp we kept the house, and though there are vents from the central heating and air, she wanted it hotter hence the ventless heater. It does put out a bunch of heat, and is very pleasant to back you backside up to when you came in out of the cold.
There is very little smell, but if you are sensitive you could notice it. I would not put one in a bedroom, the one we have is an a large room in the basement. We have run it very little since she has left in early December. But I like having it as a backup if the power goes off to keep things from freezing up and we would move down there if we had to. With the gas cookstove down there, we could heat water, and cook meals down there as well, as there is a full kitchen. I have two of the fake electric fireplaces too, one in our bedroom and one downstairs as the TV stand/fireplace. They are nice, but don't make a whole lot of heat and would be worthless in a power failure.
I also have a vented gas fireplace upstairs, but it is worthless as you must keep the chimney open and all of the heat goes up the chimney. The little ventless unit in the basement will make 10 times the heat as that fireplace with 1/3 the gas usage.
So there are pluses and minuses to the ventless unit, just like anything else. I am glad we have ours, but I would not like them as a primary source of heat.
/ Any one use a ventless gas stove for heating.??? #6
We have two ventless fireplaces (although rarely operate more than one) and there are a lot of days in the winter season that they are our "primary" heat (in that the heat pump wi ( th heat strips don't come on). We've been using them since 2007, and I'm mystified by this "film" of which people speak; nor have I ever noticed any condensation in our home. The house was finished in 2007, and it is well insulated and wrapped (although it is not super-insulated by any means). I don't notice any smell (they are propane fueled).
We recently purchased another small unit (I think it is about 8000 btu) for our new bedroom (the bedroom is about 14' x 30', with a tall vaulted ceiling, so it's not like its a little room) and I'm looking forward to having it operational to take the chill off.
Having said all that, for the most part, we might run them for an hour in the morning and 2 or 3 in evening at most, so it's not like it's continuous (some more on the weekends if we are home). All in all, I couldn't be happier with them, and they are great in case of power outage.
Good luck and take care.
/ Any one use a ventless gas stove for heating.??? #7
Besides the obvious safety concern a ventless gas puts tons of moisture in the air. I had had a renter nearly rot the windows out of the house running a ventless gas. The house had a fully operational gas furnace, but he thought it was cheaper to run the ventless gas.
/ Any one use a ventless gas stove for heating.??? #8
I have both a 95% propane furnace like you, and a ventless 30K propane heater for backup. First, you should have someone confident to check out your normal furnace. It should be up to the job of keeping you warm. The ventless wall heaters are no different than your wife turning on a burner in the kitchen. Same principle... They are about the most efficient way to heat with gas, but create moisture problems if you run them a lot. Running for a few hours each evening should not be a problem. No different that your wife cooking for a few hours with her gas stove. But get that furnace checked out.... something is not right. Maybe need to look at covering your windows with something... that is where most houses loose heat. Although the basement is also a big heat sink with block or cement walls.
/ Any one use a ventless gas stove for heating.??? #9
I agree that you should have your furnace checked. A good furnace should keep you warm. Also check for air infiltration around doors and windows.
That said, we have a cast iron ventless natural gas heater in the living room. It is good supplemental heat but not appropriate for primary heating. I like to turn it on when I come in from outdoors. Typically we only run it for an hour, then it gets too warm. We did not get a wall thermostat but I wish I had.
/ Any one use a ventless gas stove for heating.??? #10
We have used a "vented" 38,000BTU propane Vermont Castings unit for 13 years and have no complaints.I would advise going to a vented unit;wouldn't cost much more.That being said my daughter/SIL have the same unit non-vented and have no complaints.Both used as a secondary heat sources.Mine is on from Oct.-April.
I second having your furnace checked out;new home,well insulated,something is wrong with it or it was sized wrong.
I have had the furnace checked out and it checks ok. This is the second house we have had a 95% efficient furnace and never liked the other one either. In our previous house when I built it (I was a lot younger then) I put a good size wood burning furnace in the basement and run the triple 8" pipe right up through our bedroom floor in side the closet. Left closet door open all the time when burning wood and it would heat the house fairly well, especially the bed room . Then as I got older and got tired of cutting wood and hauling it and the mess, I put in a large pellet stove. It worked pretty well but not the heat the wood stove put out. When I built the latest house my wife said she didn't want a pellet stove either, because it stirred up too much dust when cleaning it. If I do put one in from all the advice here looks like I will have to run the pipe out some way. To be honest I think I am loosing a lot of heat through the duct work. I did not run insulated duct work because I wanted to keep the basement some what warm because that is where my wife does the laundry, ironing and we have a shower down there and we use it rather than the one in the bathroom. So I am sure I am loosening a lot of heat through the duct work.
/ Any one use a ventless gas stove for heating.??? #12
My cabin has electric heat pump, and a propane ventless heater that we supplement during cold weather. Really warm heat and had no issues from it. Some moisture on windows in morning, but very happy with it.
/ Any one use a ventless gas stove for heating.??? #13
If the duct work is metal & not insulated, it isn't to code.. If metal,Are you sure it isn't insulated on the inside ??
We use to do non insulated metal duct back in the 60 & 70's with heat only systems, but not in this day & time.
If you want heat downstairs, you should just cut in some registers ...
Is your duct work duct board (soft fiberglass board) ?? If so.. It's insulated
If metal, and not insulated on the inside, I would recommend you buy some mastic,apply it to all joints, and pipe run offs, then, insulate on the outside.
If your duct work is duct board.. I would mastic all joints, even where the pipes come off .
If you can't heat with a gas furnace,, you either keep the t,stat too low , it's not operating properly, or the furnace is too small, or your loosing all your heat through cracks in the duct work
/ Any one use a ventless gas stove for heating.??? #14
The furnace should still be able to heat the house even if heating the basement. Do you have insulation around the rim joist? Are the basement windows leaking air?
I would consider insulating the basement.
And a ventless supplemental heater upstairs should be workable.
/ Any one use a ventless gas stove for heating.??? #15
A ventless heater burning propane or natural gas puts all the products of combustion into the room air. Carbon, carbon dioxide, carbon monoxide, nitrous oxide, and sulfur dioxide among others. The heater also causes the air to increase its water capacity so it being dry it sucks water from everything around. Then when the air hits a cold spot like windows it condenses along with residue from those gases. Nat gas contains a lot of moisture so burning that releases it into the air. By all means if you want to live in all those gas emissions be my guest; if you are lucky you will live to tell about it.
Talk to your local Fire dept about this. They are experts at solving the things that go wrong with all those emissions.
Ron
/ Any one use a ventless gas stove for heating.??? #16
i had a ventless propane heater in a deer lease type rv, it kept it very nice and warm but if you stayed in the rv long you would come out like you had been on a 2 day drunk :confused2:
Seriously though I always learned that any open fire produces CO and that stuff needs to be vented. True story about the rv but i soon learned to keep a window open a little bit to vent the CO and it was fine.
/ Any one use a ventless gas stove for heating.??? #17
I concede those of us who live farther South probably don't have a full appreciation for what it takes to heat a home farther North, but I for one would never have a ventless "anything" that burns gas, propane, etc. We are (or were) rural, and when we built our house all we could get was total electric or propane. We went with total electric, which by the way, is given a rate break by the electric company. We have since replaced our old electric heat with a heat pump, which works fine until it gets cold, and we switch it from heat pump to resistance heat.
It's a b***h when we lose our electricity, but we had a functional fireplace built when we built the house. We can heat most of the house with it, and use it as supplemental on yucky evenings or just when we feel like it. I don't cut wood any more either; we just order a cord or so, delivered and stacked. It works for us, and I don't worry about getting CO poisoning. Sometimes get a whiff of wood smoke, which is not great for your sinuses, but otherwise we're happy. Oh, yeah; our first hard Winter, we learned that it would be wise to add another 8" of insulation to the ceiling and storm windows and doors all the way around. Saved the cost in a couple of years.
/ Any one use a ventless gas stove for heating.??? #18
They use a catalyst to produce (in theory) only carbon dioxide and water vapor as combustion products. So they put out a lot of water vapor, humidity. But they are 100% efficient in the sense that you get all the heat from combustion. Nothing lost up the chimney. My dad had one and it was nice but made the house very humid.
/ Any one use a ventless gas stove for heating.??? #19
The only time they produce carbon monoxide is when there is not enough oxygen to produce carbon dioxide and water. If they are running correctly there is no CO (carbon monoxide) produced. I don't know where this hydrogen sulfide idea comes from.. There is no sulfur in propane to produce this poisonous gas in any kind of reaction.
Here is the normal reaction in the presence of sufficient oxygen. C3H8 + 5O2 → 3 CO2 + 4 H2O + heat
Here is the reaction in the presence of not enough oxygen.2 C3H8 + 9 O2 → 4 CO2 + 2 CO + 8 H2O + heat
Notice the production of the 2 CO (carbon monoxide) molecules. Of course Carbon Monoxide is lethal. Note also in each case the production of water (H2O) . The O2 is of course is free oxygen molecules in our air. and the C3H8 represents the propane molecule itself. I hope this clears up some misunderstanding of the chemical reaction that occurs when you burn propane.
/ Any one use a ventless gas stove for heating.??? #20
Again folks.... lots of people cook many hours a day inside their house with either propane or natural gas... Some use range hoods, some not... Keep things in perspective for non-24/7 non-vented stove use. Not saying it is good for you, but neither is smoking/etc....
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A59230)
2015 International...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
