any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #711
Larger diameter rear tires and wider front tires and wheels where an option.
On a 4x4, wouldn't they have to increase the size of both front and back? Or did they adjust it with tire size or gear ratio?
   / any toro groundsmaster fans on here? #712
The rear axle is engaged with an overrunning clutch, meaning if a front wheel slips the drive shaft turns faster than the clutch, engaging it.
I changed from the smaller to the larger on my 325D and couldn't tell any difference. It may take an extra revolution of the drive shaft to lock up, but 4WD got me through several near stuck places.
   / any toro groundsmaster fans on here? #713
Ah-ha, thank you sir. Was thinking I may take my semi worn out larger rear tires off one of my 4wd units and put them on the rear of the 2wd and get new 18 tires for the 4wd on the old 2wd rims as I need all the traction I can get.
   / any toro groundsmaster fans on here? #714
Not that I know of. You can go to the Master Parts Viewer ( Toro Master PartsViewer ), but you need the 5 digit model number, not the series number.
The 345 has a gas engine, don't think there is a diesel version.
I was just throwing numbers out as examples, and yeah I've used the parts viewer, was just hoping someone had thrown a list of what all toro made in the groundmaster series. thanks Xfaxman
   / any toro groundsmaster fans on here? #715
Forgot I had a junk seat with armrests on it. This is the style I am looking for though, still need one more set if anyone knows of a supplier. I plan to replace this seat and I’m pretty sure these armrests will just swap over to the new seat.
   / any toro groundsmaster fans on here? #716
Xfaxman,
I’m noticing while mowing with the sd deck when I crest a hill and start going down the backside the mower deck will drop pretty far down. I’m afraid one of these times the pto shaft will pop out and go flailing around. How far should the deck be allowed to drop when cresting a hill? I shortened the chains a link or two, but I think they may need more. Thanks again for the help.
   / any toro groundsmaster fans on here? #717
The armrest kit is Toro 30707 but appears to be nla.
   / any toro groundsmaster fans on here? #718
Xfaxman,
I知 noticing while mowing with the sd deck when I crest a hill and start going down the backside the mower deck will drop pretty far down. I知 afraid one of these times the pto shaft will pop out and go flailing around. How far should the deck be allowed to drop when cresting a hill? I shortened the chains a link or two, but I think they may need more. Thanks again for the help.
If you have the correct driveshaft for the side discharge deck it can't come out.
I set the front chains for max lift, 11 links, like the operators manual shows.
If you have a set of car ramps, you can back up on them and lower the deck to verify the drive shaft won't pop out.
I use them to access the underside of the deck:
   / any toro groundsmaster fans on here? #719
I feel pretty silly. I couldn't figure out how to get the toro up on ramps with the deck on. Looks like it would work pretty good for cleaning.
   / any toro groundsmaster fans on here? #720
Figured it out. I need shorter ramps. My ramps are too long to fit between the wheels
I am looking for the schematic to add lights to the 223D,.
There is a place for a light switch in the panel. I have yet to find a schematic that shows where to tap in for lights.
I would think since there is a labeled hole to install the switch in the panel that it should be a matter of finding the right spot and plugging in a wire to feed the lights.
Any ideas?
Thanks
https://lookup3.toro.com/Ill/2X/6/6049/124A0004.gif?1558874430671
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
JMR 40" Mini Grapple (A57149)
JMR 40" Mini...
2023 FORD F-250 STX (A58214)
2023 FORD F-250...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
