Any tricks to find an underground water leak?
   / Any tricks to find an underground water leak? #21
Follow BIRDs advice use a 4 or6' T probe that you can push down along the pipe, then use a Mechanics Stethoscope and listen for the leak.
Search results for: 'mechanics stethascope'
one of these can be had for a few bucks on sale and you MAY be able to BARROW one thru Autozone/Advance Auto but not sure I would want a loaner tool in my ear... :x
Mark
   / Any tricks to find an underground water leak? #22
Mark, I was in the same situation as you I also have a back hoe and did the gate valves. I have about 1600 feet of one inch pvc and every leak I found was in a joint so figure out if you have 10 or 20 feet sections of pipe and find the joints you will probably find your leak in a joint.
   / Any tricks to find an underground water leak? #23
living here in upstate SC I can tell you that the ground is so wet that unless its really bbad you wond be able to tell where its leaking.
   / Any tricks to find an underground water leak? #24
Thanks for the responses. I'll try to answer some of the questions asked. The meter is at the road and past the meter is my responsibility, no help from the water department. They did put the run in about 10 years ago for the previous owner. They ran white pvc in with glue joints the best I can tell. Not exactly sure where I could get a listening device in my area. Our usage is up by 3x the last two months and about 2x more than the summer peak usage when we do some garden watering. We have shut off the water at the house and the meter still says we are running water which should eliminate any elusive toilet issues or house issues. Not sure that probing or moister meters would help this time of year. We have had some rain at least once a week for the past two months and the ground is pretty saturated. The obvious places such as hydrants have been check without signs I can identify. We do pay a leak fee each month so some of it will be refunded when I can find the leak.
Right now I think my best approach is to start spitting line in section and installing a gate valve to isolate areas. Nothing like playing in the mud during the winter. The bad new is we have a good chance of rain every day for the next 7 days. The good news is I have a backhoe.
Any other ideas are welcome and thanks for the ones offered.
MarkV
Not sure of the white plastic line installed but often is oversized possible allowing you to shove a new one inside the old...jut a thought. I would also not install any additional fittings where you test except sleeves to repair the section cut out. Any connection is a potential problem. Also, if there is any sand/gravel deposits in your area a leak may never surface. Also 3 times the water usage is a tiny, tiny leak. Depending on your temperatures, waiting a month or two wouldn't be the end of the world and mayb allow a wet spot to surface.
   / Any tricks to find an underground water leak? #25
MarkV
Do you have outside hydrants that have a shut off in the ground between the meter and the house. It would seem to me that would be a place to check. I have heard and seen pipes break by those and have seen them leak into the ground even though they work fine when operated. Just because it leaks 5-6' underground doesn't mean it will rise to the surface unless it is one heck of a gusher.
Anything other than on a straight run would be my first place to check. If it is a frost free stand alone hydrant maybe put your ear on it to check for noise in the ground from a water leak.
   / Any tricks to find an underground water leak? #26
No hints, but my experience with a leak. Several years ago we had rural property with water provided by a rural water association, which is a government welfare program. We owned the property when the system was first installed, so we got one of the initial connections. I ran a line from the meter to our proposed house site. That was about 300'. I used flexible black plastic pipe in 100' coils. I forget the name of the plastic. This stuff was later recalled and there were lots of lawsuits.
We were visiting the property about once a month. Between visits a leak developed. The line split in the middle of a section. The split was about 1' long. The leak soon created a mini-grand canyon. There was no problem finding the leak. The water association discovered the leak after a couple of weeks. They cut off the water at the meter. They had mercy on me and only charged for 40,000 gallons on the next bill.
I repaired the leak and after that I turned off the water at the meter after every visit. We never did build a house there.
   / Any tricks to find an underground water leak? #27
I would wait for better weather and get rid of the PVC pipe, there are to many fitting in 800' for leaks. You may have more than one leak, and more may occure in the future. Replace with PEX tubing, 300' roles are common, you can get in 500' or 1000' special order.
Dave
   / Any tricks to find an underground water leak? #28
Generally, white glued joint plastic pipe is 20' in length. Rural water might even be 40' lengths if they supplied the pipe.
   / Any tricks to find an underground water leak? #29
Dave
I would disagree...if you replace it purchase a high quality coiled plastic pipe Scd 7 in as long of coils as possible.
Well I sure hope not to replace the whole thing! The existing pipe is only 1" so I don't think running new pipe in it is a viable option. I'll start where the "T's" to the lateral runs are, I think I know there locations, and try to isolate it to a section. Gate valves would at least let me wait until dryer weather if it is on one of the lateral runs. If it is on the primary run I'll be playing in the mud. If anyone wants to come help I'll buy the refreshments and we have a washer and dryer for post project maintenance. :thumbsup:
Thanks all, I am off for the weekend and will check in tomorrow.
MarkV
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
New Mahindra 2665CL Loader (A50775)
New Mahindra...
2010 Chevrolet Tahoe SUV (A55758)
2010 Chevrolet...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
flooring (A55758)
flooring (A55758)
2012 Cornhusker800 43ft Hopper Trailer (A55301)
2012 Cornhusker800...
