Anyone have a LED dusk to dawn pole light?
   / Anyone have a LED dusk to dawn pole light? #171
I can't light my yard enough to see it all, so chances of randomly needing a light where I'd put one aren't likely. I carry a small flashlight everywhere I go, so that is no bother at all. I put some solar LED motion lights here and there to get my attention should I need to go check things out.
   / Anyone have a LED dusk to dawn pole light? #172
I wish I had some darkness out here. I live close enough to Branson there isn't as much darkness as I would like , especially on cloudy nights with the light from the city bouncing back down from the clouds..
The Oakland house is like this... the entire Bay Area is the back drop view from the back of the house... millions of lights and when it is clear even the lights on 5 Bay Area bridges including the Golden Gate...
Growing up I never really new what darkness was until my time in Washington...
   / Anyone have a LED dusk to dawn pole light? #173
My house is out of town, but I don't get the clear nights, because I am not far from town. That is why I like a dusk to dawn, not missing anything.
Though motions sensors, atleast the two head ones I have, provide poor light, the spots are not as good as big light up high.
   / Anyone have a LED dusk to dawn pole light? #174
What I don't like about motion sensors is they don't have a good bypass. If you want to turn the light on to see if bear is in the front yard, I have to go out on steps and wave my hands.
No one said you weren't smart but...... I'm not so sure this would be a smart move :D
On the ones I have if I turn the light switch off for 3 or 4 seconds, then back on the motion sensor is bypassed and the lamp is switched on. Do the same thing to toggle it back to automatic. If wiring new, get a center off SPDT switch and run an extra conductor with one side of the switch in series with the motion sensor and the other side direct to the lamp.
   / Anyone have a LED dusk to dawn pole light? #175
Mine is supposed to have that bypass feature, off and on. But it kicks my butt and never seems to work. Ends up stuck on with bugs. I turn it off, then forget to turn back on.
I have motion lights, not a fan, but they are better then the dark.
I'd like to know if better ones are out there. I am tired of going on extension ladder and cleaning it and still just as bad. Not as good as it was when I put in. Maybe more expensive ones are better, or maybe technolgy just isn't there.
   / Anyone have a LED dusk to dawn pole light? #176
The last four pages I skimmed through illustrates the problem with LED's. You simply cannot compare them apples-to-apples and that's my opinion.
I can't hold up a 100W or 300W bulb and compare those to LED's in a simple fashion. If anything, the info given makes comparison less likely and most of us are programmed to avoid that kind of thing but maybe that's just me.
   / Anyone have a LED dusk to dawn pole light? #177
Most all motion lights are still switch activated.
   / Anyone have a LED dusk to dawn pole light? #178
Yes, but you still need motion for the light to come on.
I bought one with an over ride sequence, just doesn't seem to work that good. Maybe others do.
Lights shine farther then motion activates them is the problem. So you are walking in dark for awhile waiting for it to turn on.
I use them, but they can really suck. Maybe a timer would be better, on until 9 or 10pm. But I find myself running out to the truck in my underwear at all hours for stuff.
   / Anyone have a LED dusk to dawn pole light? #179
1. Yes, but you still need motion for the light to come on.
2. Lights shine farther then motion activates them is the problem. So you are walking in dark for awhile waiting for it to turn on.
3. But I find myself running out to the truck in my underwear at all hours for stuff.
1. Not if you toggle the light switch on newer ones per my earlier post, no motion detection is required. How old is yours?
2. Modern ones have a sensitivity adjustment. Yes, the light may shine farther than the motion is able to be detected but that is mostly when approaching from straight on. Not so much when approaching from other angles. A lot has to do with where you locate the light.
3. I hope you are far off of the county road :D
   / Anyone have a LED dusk to dawn pole light? #180
I have motion sensor I bought 5 years ago that said you could cycle the power to get it to come on. Never got it to work. Maybe just need another. It is above the porch and so have to be on the icy steps before it comes on. Plus sometimes I just want to look outside.
I have maxed out sensitivity, but the ranges are still less then light shines.
At my camp, I may trench and put out a yard light, with a switch inside. One of these days.
1998 ford f450 (A53422)
1998 ford f450...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55218)
2016 Ford F550 4x4...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
