Anyone have problems with the Rollover Link
   / Anyone have problems with the Rollover Link #21
We all know that PT (Terry) suggests using superlube, which is a mix of an oil and teflon. My only concern with white lithium would be getting good enough penetration to lubricate the inner portion of the swivel. If the lithium grease penetrates well, it has better high pressure performance, which is what we would want.
All the best,
Peter
My PT-425 rollover links, neither the original or the new replacement, have grease zerks -- just the ball/socket swivel like those on the ends of the steering cylinders. I've been spraying them with white lithium grease.
   / Anyone have problems with the Rollover Link #22
All the best,
Peter
On the rollover link, at least, it's fairly easy to wiggle the link and try to get penetration/coverage of the ball. It's some of the connections, like the lift arms or the QA that really concern me, similar to SnowRidge...
I think this is a key difference between PTs and true, industrial/commercial grade equipment. PT takes a good, innovative design and cuts corners in order to keep the cost down...
IMO, these are truly HD consumer/light-commercial machines, all the way around. For example, just imagine the wear/tear on one of these at the 3,000 - 4,000 hour point, which isn't at all unusual for landscapers and such...
That's not saying that I'm disappointed with my PT in any way -- I still consider it the best $$ spent on tools in my lifetime. Just pointing out that it's truly a different animal... But, I'm not sure I'd want to try making a living, depending on it.
   / Anyone have problems with the Rollover Link #23
McMaster has a number for about $10/ea, if you want to change yours...
I'm sure that you could find others.
All the best,
Peter
I asked Terry about that. He said swivels with zerks were so expensive that you could replace a couple of regular swivels for the price of one with a zerk.
What I don't get is all the lift arm parts rotating on bolts, with no lube fittings anywhere except the rollover tube. The Ansung loader on my Branson has hollow pins with zerks everywhere.
So you guys are now thinking that these things need to be greased.
All the fittings on that bar have been replaced. Originals are gone. I have one more non grease which I may weld on, then start greasing them.
The thing though is why aren't the ones on the piston rods greased. Those take a heck of a lot of abuse for sure.
   / Anyone have problems with the Rollover Link #25
Carl, Every fitting on the PT should be lubed. Metal to metal is not a good thing.
   / Anyone have problems with the Rollover Link #26
I completely agree with this assessment. I have also bent this cylinder a couple of times as well. A complete mystery to me why this cylinder is so weak. I have yet, though, found a cylinder at Surplus Center I feel would work. Still looking. Any thoughts? I think I have the dimensions around here somewhere (I am back in LA for the moment).
Carl, If you can not find a cylinder, Bailey Hydraulic Cylinders Manufacturer can make one for you in any size.
   / Anyone have problems with the Rollover Link #27
Carl,
On my 1445 they are all zerks for greasing. As JJ writes, if it moves, you want it lubricated, i.e. greased.
All the best,
Peter
   / Anyone have problems with the Rollover Link #28
David, I think Carl would destroy that top-link in short order. He is doing some serious landscaping on his property.
I agree, but it can't hurt to try. After he destroys it, he can still use the ends on a solid piece of stock as a replacement. It just won't be adjustable.
And speaking of grease... does anyone grease the ball ends on a 3PT hitch on a regular basis? Nope. Because they do not swivel too much.
   / Anyone have problems with the Rollover Link #29
Ponytug,
Are you saying all your ball ends have a grease zerk? For example, on the loader arms.
I actually thought greasing these items (with spray) was a bad idea because it would attract dirt and grit.
   / Anyone have problems with the Rollover Link #30
Dear Marrt,
Yes, every joint has a zerk on my 1445, except for the 4 swivel ends on the two hydraulic steering cylinders. Put another way, every point that rotates on the front end has a zerk associated with it.
Having a zerk at each point does simplify the greasing because you go down the list, top, bottom, left, top, bottom right,... MR had written sometime ago about having a greasing point sheet, which I considered, but since everything gets greased, it is pretty easy. (Well, except for the inboard end of the linkage arm cylinder, which is just plain awkward.) If you have a mixture of zerk and spray, I can see the utility of the list.
The dirt seems to stick to the excess grease, so it seems OK. Despite lots of dust, I don't seem to get much sticking to the superlube either. In my limited experience, both seem to work well. I can see that greasing the 4N1 bottom swivels might be problematic, as they get dragged in dirt a fair amount.
All the best,
Peter
P.S. The ball ends on the 4N1 bucket are spray lubricated, but the rotation points have zerks. Go figure.
Ponytug,
2012 GMC Savana 3500 Passenger Van (A55852)
2012 GMC Savana...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
UNUSED IRANCH IRTPL 10,000# TWO POST LIFT (GRAY) (A57193)
UNUSED IRANCH...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
1454 (A57192)
1454 (A57192)
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
