Apps for land survey - Property lines
   / Apps for land survey - Property lines #1
Junguda
Tennessee
Kubota L3400 HST
Does anyone have experience with land survey apps...? I’ve read about “Theodolite”, but need a specific function... I’ve got two turn points, and need to walk between them and be able to tell when I cross that property line...
Uhhhh.... never mind.. I found the thread from 2018.... Apologies...
   / Apps for land survey - Property lines #3
could you direct us to that thread? i can't find it
thanks
So I installed “BaseMap” and walked out to the property line... it shows a green dot with arrow as I walk around and it’s within 10 ft of accuracy.... as I’m on the SE border of our town lot... plan to try it at the farm tomorrow...
   / Apps for land survey - Property lines #6
I commented on the other thread to but I am a land surveyor. I feel the need to comment on this one. There is nothing wrong with using an app like this if used for the right reasons. You wouldn’t want to use it to build anything, say a building or a fence. You might think you have 10 feet accuracy, but for a lot of reasons it might be worse than that.
Thanks Dodge Man.... as a surveyor, how much do you charge to explain the terms in a deed...?
   / Apps for land survey - Property lines #8
No disrespect meant to DodgeMan, but I believe you want a title attorney for the answers you are looking for. Unless you want somebody to actually look at your lines, then the D-Man is your man!
   / Apps for land survey - Property lines #9
Some attorneys are good at reading deeds but not many. I will interpret deeds for people and explain them if possible. It’s pretty rare anyone asks for it though, they usually want it surveyed to. Probably just a few hundred dollars to figure a deed out, if it’s simple I will often do it for free. I’m not licensed in Tennessee by the way.
No problem... Neighbor said he’d send me a copy of the survey he had done for the building site...should clear up the question.... but thanks for the info...!
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Sundowner Rancher Express 20FT Livestock Trailer (A55314)
Sundowner Rancher...
2017 John Deere 5090GN (A53317)
2017 John Deere...
