At Home In The Woods
   / At Home In The Woods #1,221
Obed,
I've used Rainflow on several houses including my Mom's. She has a huge maple tree that filled her gutters with seeds in the spring and leaves in the fall. I used to clean her gutters 2 and sometimes 3 times a year. We tried different types of screens. Most worked ok for leaves but none could keep the "helicopter" seeds out. So I'd have to pull the screens to clean the seeds out. I found that no screens were better than using the screens when it came to the maple seeds......until I found Rainflow. My gutter cleaning days are over. At least at my Mom's house. I haven't installed Rainflow in my gutters....yet. I'm going to replace my roof in the next year and I figure I'll install Rainflow then.
Pops
   / At Home In The Woods #1,222
Obed:
8/12 is a very steep roof pitch.
The roof will be slippery from water, wet leaves and possibly ice. Falling off will ruin your whole day.
Tying yourself to the chimney with a rope sounds like a way to re-enact an old-time hanging. At a minimum get a proper harness to wear.
I have seen and used gutter cleaners that are essentially long extensions for a leaf blower with a U-turn at the far end. You stay on the ground lift the end up into the gutter and blow out the leaves.
Needless to say the disadvantage is that you get a full & complete shower of all the stuff in the gutter coming down on you, but a rain slicker and a logger's hard hat will make it a lot easier to take than a fall from the roof.
Better yet, hire it done. In Grants Pass I can get a guy to clean my gutters for $100. I don't know what his technique is, and I have never watched him. But that is chump change for not having to take the chance of falling off the roof.
I agree with CurlyDave. I think if you have to tie yourself to something you should find another way to do it, and hiring it done may not be a bad deal. Just make sure whoever you hire is insured because as much as you falling from your roof can ruin your whole day, having someone else fall off your roof isn't far behind, especially if they aren't insured.
   / At Home In The Woods #1,224
Cabinet Update
Thanks everybody for the responses to my cabinet questions. Nobody seemed to be thrilled about the metal drawers and neither was I but your comments helped us to decide.
We spoke to the most expensive cabinet maker this afternoon about some options we wanted that were not in his estimate. We told him we wanted dovetailed wood drawers, not the metal ones. He sent us a revised estimate that is $500 higher than his previous estimate. He said he likes to structure the payment schedule at 50/40/10 instead of 50/50 because sometimes there are long construction delays caused by other subs that delay him from being able to finish the job. He agreed to accept 50% down, 50% on completion payment schedule instead of the 50/40/10 plan if he gets the job.
He is $3500 higher than the next highest bid. I asked wife if she likes him $3500 more than her second choice cabinet maker. She is going to sleep on it.
We have a verbal agreement with the most expensive cabinet maker to give him the job; paperwork will be completed in the next day or two. The payment schedule will be 50% down, 40% on primary installation, and 10% upon completion. Primary installation is defined as the cabinet boxes are installed, all the hardware is installed, the doors and drawers are completed, but some minor things like a kickboard installation that is waiting on the H&A vent installation might not be installed.
   / At Home In The Woods #1,226
Obed, like you my home is in the woods. We thought we were doing ourselves a favor by having leaf guards installed. Great idea in theory but here in the upper midwest any water that melts on the roof during winter promptly refreezes on the aluminum guards and creates large ice dams. You won't have the winters like we have but it is still a concern. I'm trying to decided if I want to install deicing cables or just remove the guards completely.
The HVAC guy had to cut through the house wrap and sheeting to install the solid H&A ductwork in the trusses. He patched his holes using the same sheathing and house wrap pieces that he cut out.
attachment.php
Unfortunately, these patches were not be very water tight. He made 4 holes. The picture shows 2 of the holes.
attachment.php
So this evening I got some scrap house wrap pieces from the scrap pile and patched the house wrap to make sure everything overlapped for water protection.
Eyebrow Question
attachment.php
Brick will be laid from the footer to the eyebrow shown here. After the brick is laid, the vinyl soffit will be installed under the eyebrow. The vinyl soffit will be attached to the brick using J-channel. One of the vinyl subs said the horizonal ledger board that attaches the bottom of the eyebrow to the wall will cause a problem. The other two vinyl subs said they don't anticipate a problem with the ledger board. We don't intend to have a frieze board or any trim below the eyebrow soffit as we think it would look bad on our house.
Do you guys see this setup as a problem? Will we end up with a gap between the brick and the eyebrow soffit? What's the solution.
Thanks in advance,
Obed
   / At Home In The Woods #1,229
Obed I was looking at your picture where you patched the house wrap. Do you have any house wrap tape? You really should tape those seams. The house wrap not only keeps out the water it keeps air from infiltrating the house. The tighter you can make the envelope the better off you will be when the wind blows.
Rick
I attached a couple of pictures that I hope will better explain what I am talking about... you know a thousand words...
nhkabotab7800,
It's been a while since you posted this message but it is coming in real handy now. We have picked the brick mason and are writing down some specifics about the brick job that we want to make sure he does. The deck ledgeboard flashing picture you provided is very helpful. I'm sure we wouldn't have gotten the flashing done that way if you hadn't provided the picture. It wouldn't have occurred to me to put flashing over the ledgerboard.
Thanks very much,
Obed
2014 Volkswagen Diesel Passat Sedan (A56859)
2014 Volkswagen...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLANCH...
CFG Industrial SAII100 Forks (A57149)
CFG Industrial...
