Attaching 3 point implements
   / Attaching 3 point implements #21
I also use the hydro pedal from the ground to move the tractor forward or back as needed to get lined up.
You can also do that with the FEL. Curl the bucket in the dump position, drop the bucket to the ground and put it in the float position, and use the dump and curl on the joy stick to rock the tractor forward and aft.
Joe
   / Attaching 3 point implements #22
Joe
That is what I used to do and it worked quite well. Since the new tractor has the extendable ends on the lift arms I haven't needed to do that with it.
   / Attaching 3 point implements #23
I don't do it any more either since I bought the Pats ECS.
Joe
   / Attaching 3 point implements #24
I make the wife do it! :D
2017 Ford F-250 (A55973)
2017 Ford F-250...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2010 Freightliner M2 106 Log Truck, VIN # 1FVACXDT2ADAT4709 (A57453)
2010 Freightliner...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
2018 Nitro Sport Z19 Boat (A57453)
2018 Nitro Sport...
