Attaching 3 point implements
   / Attaching 3 point implements #21
I also use the hydro pedal from the ground to move the tractor forward or back as needed to get lined up.
You can also do that with the FEL. Curl the bucket in the dump position, drop the bucket to the ground and put it in the float position, and use the dump and curl on the joy stick to rock the tractor forward and aft.
Joe
   / Attaching 3 point implements #22
Joe
That is what I used to do and it worked quite well. Since the new tractor has the extendable ends on the lift arms I haven't needed to do that with it.
   / Attaching 3 point implements #23
I don't do it any more either since I bought the Pats ECS.
Joe
   / Attaching 3 point implements #24
I make the wife do it! :D
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
Krause 4223 Field Cultivator (A59814)
Krause 4223 Field...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
