Attaching 3 point implements
   / Attaching 3 point implements #21
I also use the hydro pedal from the ground to move the tractor forward or back as needed to get lined up.
You can also do that with the FEL. Curl the bucket in the dump position, drop the bucket to the ground and put it in the float position, and use the dump and curl on the joy stick to rock the tractor forward and aft.
Joe
   / Attaching 3 point implements #22
Joe
That is what I used to do and it worked quite well. Since the new tractor has the extendable ends on the lift arms I haven't needed to do that with it.
   / Attaching 3 point implements #23
I don't do it any more either since I bought the Pats ECS.
Joe
   / Attaching 3 point implements #24
I make the wife do it! :D
American G-Model Pump Jack (A56438)
American G-Model...
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
