Attaching hooks to a goat's horns to prevent escape?
   / Attaching hooks to a goat's horns to prevent escape? #1
KYErik
Platinum Member
South central IL
1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I have a problem goat.
It has been testing the 6" square field fence and has discovered that if it pushes the bottom of the fence up in a low spot, it can wiggle its way under the fence on its belly. I have several low spots along the perimeter of the pasture, so it would be a big job to fill them all in.
The goat also has an intermittent issue with putting its face and horns through the fence so it can eat grass on the other side, and then not being able to get its horns back through so I have to "help" it get out about once every 1-2 months.
I tipped the goat's horns several years ago, so now they are about 10 inches long and curved backwards.
My idea is to connect a forward facing "hook" to each horn so that whether he tries to slide under the fence or even if he tries to stick his head through the 6 inch holes in the fence, the forward facing hooks will catch on the wire and stop him.
I was going to slide a 1 inch PVC pipe over the top 4 inches of each horn and then put a 90 degree fitting and another short pipe facing forward, but the horns have an oval shape in cross section so the pipe won't fit very snugly. Any ideas?
I would use a low electrified wire, but the horse shares this pasture (he and the goat are friends) and I am afraid he will step on the wire and get tangled).
   / Attaching hooks to a goat's horns to prevent escape? #2
We had a doe deer that would lift chain link fence up this way but the only low spot led into a divider so she didn't get out, only in where the grass was taller (she was happy there). Anyway, what we did is just cut a small diameter tree (you can use store bought wood if you want) and anchored the wire to the tree along the bottom. Now the doe can't raise the wire as the log ran post to post. We only had a couple spots to deal with but it is a lot easier then trying to fill low spots and creating little ponds if you only fill the fence line.
   / Attaching hooks to a goat's horns to prevent escape? #3
I'd run that electric wire.. We have ankle high electric around our pasture with horses... they get buzzed exactly -1- time then they stay about 10' away from the fence..
Soundguy
   / Attaching hooks to a goat's horns to prevent escape? #4
Soundguy
...+1
   / Attaching hooks to a goat's horns to prevent escape? #6
Theres a reason its testing and most of the time its about food or boredom. OTOH if its about *** no man-made restraint will work. Instead of messing w/ the fence perhaps solving the basic issue would be better in the long run?
   / Attaching hooks to a goat's horns to prevent escape? #7
I had a goat that would stick it's head through the fence and get stuck about 3-4 times a week. I took a 12 piece of PVC, I guess it was 3/4 or 1" diameter and duct taped it across it's horns about half way up it's horns. That will stop it from sticking it's head through the fence. Might keep it from going under.
   / Attaching hooks to a goat's horns to prevent escape? #8
Sounds like a hassle to me.
If I had a goat that presented that much trouble, I guess I'd just eat him.:)
   / Attaching hooks to a goat's horns to prevent escape? #9
Dehorning will solve the problem of getting caught in the fence, going under can be solved with the electric wire. If it fails I do know that a good bbq will work!;)
   / Attaching hooks to a goat's horns to prevent escape? #10
We had a goat that would challenge me like this all the time. What worked for me was to tie her to a cinder block. That way, when she jumped the fence, I found her on the other side:)
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Pickup Truck (A59230)
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
Chemical Containers Tank (A57148)
Chemical...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59575)
2019 INTERNATIONAL...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
