Attaching wire feed to a stick welder
   / Attaching wire feed to a stick welder #11
Is this what your welder looks like? This is mine and if it looks like this it is definitely more than 10 years old. I think lincoln may have some info on their site.
   / Attaching wire feed to a stick welder #12
Wait a minute, are you saying that a CC stick welder can run flux wire?????
Yes sir, that picture I posted of the Hobart 21-B weld was made with my 1966 SA-200 Red Face CC only machine. But if you plan on doing code work where T-8 wire is required, you'll need CV.
I know that there are "voltage sensing" wie feeders that claim to be able to run from a cc machine, but not sure how well they work.
Yes the LN-25s are voltage sensing wire feeders. In my opinion that work great! ;)
   / Attaching wire feed to a stick welder #13
You know anything about the ln-7? I could get an older one for free, but I don't think it would work.
   / Attaching wire feed to a stick welder #14
I also have a 30a spoolgun that I know I could make work with the right adapter, but I don't think I want to use a spoolgun all of the time.
   / Attaching wire feed to a stick welder #15
Not really. I have run them before. I'm pretty sure they won't work with the Idealarc CC only machines. The LN-7s, 8s, and 9s, all need to be wired direct to the power source. They are not voltage sensing wire feeder.
   / Attaching wire feed to a stick welder #16
I've always heard you can't run Mig on a CC machine. I wanted to see what happens, so I gave it a try. This is .035" Lincoln L-56 wire, with C-25 gas. Ran it on the same 1966 SA-200 Red Face CC only engine drive, with my LN-25.
   / Attaching wire feed to a stick welder #17
You heard right didn't you? ;)
   / Attaching wire feed to a stick welder #18
And you call yourself a welder....
:laughing:
   / Attaching wire feed to a stick welder #19
You can use a Lincoln LN-25 or a Miller 12vs both of those are voltage sensing wire feeders and will run on a CC stick or tig machine (really need to keep it in Spray transfer). be hard pressed to find one in good condition for less than 500 though.
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
