Attempting to save a gasket for reuse- TIPS OR TRICKS?
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #21
P.S. - if you aren't doing so already, try and use non-ethanol gas in your tractor.
Thats a big 10.4 . As of last year I've started using non ethonal gas in my machines. Costs a little bit more/gal. (about 35 cents) but should be cheap PM.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #23
Very low cost PM ! Energy value of pure gas is higher than the E stuff, so the cost per/btu is good.
On pumps that share hoses with E, run at least a gallon into your car, b4 filling gas cans, to flush the pump out.
Rgds, D.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #24
got the double-post glitch too just now....
Rgds, D.
   / Attempting to save a gasket for reuse- TIPS OR TRICKS? #25
If you get desperate try looking for a new one. I tried to rebuild my Sears Generator's carb last year with the usual success. Then I started looking on the net using the make and model on the carb body. I found one for $35 on Amazon Prime of all places just like body parts for my truck, whod a thought?. Anyways, I stuck it on and never touched it, worked fine. Ethanol gas is the usual suspect. It just plugs small carbs while it seems fine in the larger ones.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
159116 (A60430)
159116 (A60430)
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
