auger point
/ auger point #1
citytransplant
Central New York
Farmtrac 270DTC
After looking high and low for a replacement point for a 12" auger I finally found what I thought to be a suitable fit. After returning home from TSC with the new unit, I was disappointed to find that the diameter of the non-business end of the point exceeds its receiver by about 1/8".
Three questions: 1. Would it be costly (or even possible) to take this to a machine shop and have it turned/shaved by 1/8"?
2. As seen in photo, the replacement point is longer than the original (although maybe not as I got the PHD used and the old point may have been equally as long as the new a while ago). Should I be concerned about the discrepancy in length?
3. Any alternative solutions?
Thanks in advance.
/ auger point #2
Make sure the end of the tube isn't mushroomed inward. If that's the case a half round file might fix it.
It's crude but you may be able to grind the OD down to fit. I don't see an easy way to chuck it in a lathe.
/ auger point #3
That piece will easily chuck in a lathe, take it to a shop their standard 3 or 4 jaw chuck will expand and catch the ID of the work piece... How thick is the metal? Can a 1/16 be removed without it being too thin? If so it's an easy turn down... KennyV
/ auger point #4
Hi, what is the ID of your auger femail end tube?
Thanks in advance.
/ auger point
I'd take the new one back & build up the old one with hardfacing welding rod. MikeD74T
That's a mighty nice offer Mike but it would be quite a trip for you from New Hampshire to Central NY.
All joking aside, I simply don't have that skill set ... yet.
The ID of the female receiver = 1 7/8"
The metal is solid Kenny, as seen in photo. I take it that you think that as long as the lathe chuck can securely grasp the point, shaving 1/16" from the 2" diameter male (non-business) end of the point (facing us in the photo below) shouldn't be a problem and should slim the diameter of the bit down by a total of 1/8".
Comments?
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
1998 MACK CH613 WINCH TRUCK (A63569)
1998 MACK CH613...
2021 John Deere Z930M Zero Turn (A63116)
2021 John Deere...
Location (A63109)
Location (A63109)
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2023 Kubota L6060HST Compact Utility Tractor (A63118)
2023 Kubota...
