B2150
   / B2150 #1
daro
Alleghany County,NC
Does any one have any sggestions on pricing a one owner B2150 with 1200 hrs. Tractor is well maintained with FEL. Rear Finish Mower, Rotory Mower, and Rear Blade. Many thanks in advance. Daro
   / B2150
1993 B2150HSD 4x4 w/Canopy. 50% turf tires several dings and cracked hood. Seems to run OK. Manuals and some sevice records.
LA350 FEL, Del Morino 6' 3PH Finish Mower, 4' Bush Hog Rotary Mower, and Gill 5' BL-60 Scrape Blade
Thanks,
Daro
   / B2150 #4
I would expect about $12k for that around here, with just the FEL and a box blade. Add more for the two mowers.
The B2150 is the next newer model to my B8200. I have about the same hours; 1200 hours is nothing on these tractors; the rings in the motor are just getting seated :D Mine has paint fade, but otherwise is in great shape(old cosmetic dent in hood too).
I have a friend with a B2150. Nice tractor.
Thanks,
Daro
   / B2150 #5
There is a B2400 with LA351 FEL and 723 hrs on eBay for a buy-it-now price of $7975 (Chambersburg, PA).
The B2400 was the replacement for the B2150. It is also 24Hp, but a 3cyl, instead of 4 cyl (not significant, IMHO).
If not a box blade, a used rear blade can be anywhere from $100-$500 depending on make/model size.
Rear finish mowers can be had for around $500-$800, same for the rotary mower.
All this said, I think $12k might be a little high for the package, as you could buy this one, and the implements separately for a bit less.
DISCLAIMER: I am not the selling this tractor, nor do I know the seller. I just like to look at CL and eBay listings for fun (although it does occasionally result in a purchase -- I just bought my B7610 w/ 124 hrs on it about a month back -- got en even better deal than above :D).
I also say a B2150 w/ 412 hours, and a Bush Hog branded FEL go for $6200 on eBay a couple months back (also in PA, no other implements included).
I'd say, a good price for the package you asked about is around $7-8k, depending on condition, and make/models of the mowers and blade.
   / B2150 #6
The B2150 is closer to a industrial B20/21, than a B2400. Built a little beefier, three range tranny/HST. I'd take a B2150 overr a B2400(although the B2400 is still a nice tractor).
Prices are regional; those packages would go for more out here...
   / B2150
Thanks for the info.
I found an old thread via the search option which linked me to some average sell figures. Also have had some very helpful Kubota sales reps at dealerships help with this as well. From my research, I should be able to get this package for around $5500.00.
The information on this site from is an invaluable resource for novices like me. I want to express a sincere thank you to all who are willing to take the time and share their knowledge.
Thanks,
Daro
   / B2150 #8
Thanks,
Daro
If you find that package for $5500 -- run, don't walk, to buy it. That would be a very good deal.
I haven't seen any decent B2150's with FEL and no other implements go that cheap. I've seen a couple B1750 (very similar, but with a 20HP 3cyl) in that price range with FEL.
RobertN makes some interesting points about the B2150 being heavier-duty design, and having the 3 range hydro. It depends on your application, if that matters. The B2400 is a newer model, and you'll be more likely to find lower-hours examples of them. It also have a flat deck, which some people like ( I have a B7610, which has a flat deck, and had a B7100, which doesn't -- flat deck doesn't really matter to me).
One other consideration that was brought up in some of my queries on this subject a few months back, was that the newer model will be easier to find model-specific attachments like FEL's, back hoes, front-mount snow blowers, etc. Of course, non of that matters if you get a package that has all the pieces you need.
For what it is worth, I have a friend that has over 1300 hrs on a B2150, and it is been a trouble free unit for him. He has followed the maintenance schedule to a 'T', so I'm sure that helps.
   / B2150
Thanks Jas.
I was just looking at the photos from when I stopped by to see this setup and noticed that the exhaust is on the right side facing forward. All of the photos I have seen on the web show the exhaust on the left. Any ideas. I'm driving back tomorrow to test drive and seriously look this tractor over.
The dealer I talked with verified the serial # as a US market unit so I know its not a Gray market tractor.
Thanks,
daro
   / B2150 #10
Thanks Jas.
Thanks,
daro
Daro,
That is very strange..... every one I've seen has the exhaust on the left.
   / B2150 #11
What model replaced the B 2400 and what year did it happen?
   / B2150 #12
B2410 is the closest replacement,in 2000, but it isn't that clear, because the B2400 was top dog of the B7300/B1700/B2100/B2400 line.
Where the B1700/B2100/B2400 tractors were the "deluxe models" with features like power steering, and position control, and the B7300 was the "standard" tractor.
That line was replaced with the following lineup:
B7400/B7500/B7800/B2410/B2710/B2910. Where, once again, the B2x10 models are the "deluxe" models, and the B7x00 are the "standard models".
So, while the B2400 was top dog from '95-'99 with 24HP, the B2410 was the entry-level "deluxe" B w/ 24HP, and the top dog was the B2910 at 29 (or 30) HP. The B2710, B2910, and B7800 are also larger frame tractors than the B2410 (and B7xxx) with 6" more wheelbase, and larger wheels/tires.
HP(engine/PTO) for these the 1995 lineup is as follows:
B7300 16/12.5
B1700 17/13
B2100 21/16
B2400 24/18
HP(engine/PTO) for these the 2000 lineup is as follows:
B7400 16/12.5
B7500 21/16
B7800 30/22
B2410 24/18
B2710 27/20
B2910 30/22
The B7400 and B7500 were replaced with the B7410, B7510 and B7610 in 2004. The B7400, and B7410 both had manual steering, the rest, power steering. Once again, the HP (engine) was upped from 16 and 21 to 21 and 24.
HP(engine/PTO) for these the 2004 lineup is as follows:
B7410 16/12.5
B7510 21/16
B7610 24/18
There you go, a long answer to a short question.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
17501-FL (A56857)
17501-FL (A56857)
Case SV280B (A60462)
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
