B3030 LA403 loader still crooked....
   / B3030 LA403 loader still crooked.... #101
scraped ice build up ona driveway today with my new 3030 . It was level. I guess I don't have this issue..
   / B3030 LA403 loader still crooked.... #102
Well I should be able to scrape the driveway now. I just got the tractor back from the shop and the FEL is now level. My hat's off to the guys in the garage for a job well done.
Gordon
   / B3030 LA403 loader still crooked.... #103
What did they do/replace to correct?
   / B3030 LA403 loader still crooked.... #104
They replaced the loader frame a.k.a. "boom arms" on it. This took care of the problem I was having. They also tried new rear tires (matched set) and upright frame mounts before installing the boom arms but they didn't seem to change a thing with the crooked loader syndrome.
Gordon
   / B3030 LA403 loader still crooked.... #105
I just bought a used B3030 with cab and the loader is off.
Does the dealer and Kubota know exactly what the problem is and which part I will need to fix it , since it out of warranty I only want to buy the part that will fix it.
Or is every loader different , I followed all the threads but it doesn't seem like it's just one part. Or am i wrong Please if someone could tell me what it is going to take to fix this problem I would appreciate it very much.
   / B3030 LA403 loader still crooked.... #106
How much is your loader off? Mine was off 3/4". My dealer tried the uprights different loader booms ect and the best he could get it was 1/2 or so. I just sloted the holes one the high side upright and now its perfect. I think they said there was 1/4" tolerence or something like that. I'm not saying how i fixed mine is the best fix for every loader it just worked for me.
   / B3030 LA403 loader still crooked.... #107
In would say about an inch off.
So you removed your upright from the frame and slotted all the mounting holes on the upright and reinstalled. that did the trick?
both side or just one? When you say slotted did you just drill them bigger or oblong the holes?
   / B3030 LA403 loader still crooked.... #108
I just used a die grinder to oblong the holes on the high side upright.It wasnt much just cleaned the hole up. I oblonged the 6 holes that are close and didnt touch the others. If you look at the holes they looked punched instead of drilled. I think if they would have drilled the holes they could have held a higher degree of accuracy. I think the hole's and other manufacturing jigs contribute to the uneven loader.
   / B3030 LA403 loader still crooked.... #109
Hi barnboy, how close is the fel to dead level now?
   / B3030 LA403 loader still crooked.... #110
Long thread but it touched home.
My 724 on the 3240 was crooked. About 1 1/2" off
Dealer changed my rear tires. didn't help.
I told him I thought it was the bucket based on my personal measurements.
He put on a new bucket and it is now perfect.
Easier fix than you guys. I guess I was lucky.
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2016 Ford F-550...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
2015 Hyundai Sonata Hybrid Sedan (A53424)
2015 Hyundai...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
