battery terminal corrosion
   / battery terminal corrosion #51
</font><font color="blue" class="small">( Thanks Mike we will give Optima a call )</font>
I just don't get all the Optima raves. Unless I'm missing something, any AGM battery functions identically to Optima. Why Optima? Because they cost 30-40% more than other AGM batteries? Or is it those cool looking round cell compartments? /forums/images/graemlins/smile.gif
Hey PineRidge, If you find an Optima (or any other group 24 AGM battery) with mounting brackets, please let me know. I don't want to weld or bolt a battery frame on to a brand new tractor.
   / battery terminal corrosion #52
<font color="blue"> spent most of the day cleaning up the acid/rust mess that the original battery made and after I paint it I don't want to be going through this scenerio again in the near future. </font>
I'd try to get your dealer to replace those componets rather than you just cleaning them up. I'd hate to see your machine fail a year after the warranty is up. Worth a call to the service manager to discuss it anyway...
   / battery terminal corrosion #53
<font color="blue"> Unless I'm missing something, any AGM battery functions identically to Optima. Why Optima? </font>
Do you have a source for AGM batteries that will fit in a Class II and a Class III Boomer?
   / battery terminal corrosion #54
Have_Blue I'm going to break out the stick welder and attach a couple of short pieces of angle iron to support the J rods.
I am sure your battery configuration is quite similar. If you don't wish to weld on a new machine some stout bungee cords should work quite well in keeping the battery where it belongs.
I'll attach a couple of pictures once I'm finished.
   / battery terminal corrosion #55
The dealer replaced mine with NAPA's sealed battery. Here is a picture of it with the bracket he fabricated.
Mark
   / battery terminal corrosion #56
'nother.
Mark
   / battery terminal corrosion #57
</font><font color="blue" class="small">( Do you have a source for AGM batteries that will fit in a Class II and a Class III Boomer? )</font>
No, I thought you did. /forums/images/graemlins/smile.gif
All seriousness aside, I can't find any 10" battery with mounting brackets molded into the battery case.
If I could find a battery that I could bolt on, my dealer would pay me for it.
I'm tempted to get an inexpensive Concorde or other AGM battery and make a custom mountig frame for it.
   / battery terminal corrosion #58
</font><font color="blue" class="small">( 'nother. Mark )</font>
Hey Mark, that's a nice bracket you made. I like the way it uses the existing hold down stove bolts. The wide strap instead of a "J" bolt should make the bracket and battery stable without sitting in a snug frame. I will try to cook up something similar without welding. I don't have a welder just now. /forums/images/graemlins/frown.gif
   / battery terminal corrosion #59
The Class II Boomers utilize;
- 2 pieces of 1" x 1" angle iron
- 2 J bolts
- 2 holes
One piece of angle iron is attached right in front of the radiator and serves and a 'back stop' for the battery.
The other piece of angle iron has a hole in each end for anchoring the threaded end of the J bolt. The hooked end of the J bolt slips into a hole drilled in a vertical tab (one on each side of the battery) attached to the steel tray the battery sits on. However, I imagine a simple hole drilled in the tray, without the vertical tab could work, too.
Here's a picture that shows the angle of the J bolts and the piece of angle iron that secures the top of the battery. The 'back stop' is covered by the leaves! /forums/images/graemlins/blush.gif
   / battery terminal corrosion #60
Have_blue I spent a couple of hours today after ordering the optima battery reworking my battery tray. I tried to keep it as simple as I could and yet still give the new battery the support that I believe that it needed. I temporarily tacked the piece of angle iron on the original base pan so that I might check the fit with the new battery before I finish and paint the project. I would expect to see the battery shipped via UPS within about 3 days. At that point I'll snap a couple of pictures, maybe it will help you.
By the way when I was picking up oil at my local Auto Zone today I spotted Optima there also. I just might have saved myself a 3-day wait if I would have known that before placing my order online…….
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
LOT OF CHAINS (A58374)
