"Best" synthetic hydraulic fluid for the money?
   / "Best" synthetic hydraulic fluid for the money?
Thanks Peter.
When choosing a motor oil to use as hydraulic oil (in my PT422 specifically), should I be concerned with whether is contains "friction modifiers" or not? For example, I used to use Rotella T 5w40 in my bike so it wouldn't adversely affect the "wet clutch" operation. Are there those types of concerns in the PT hydraulic system?
Thanks again everyone!
   / "Best" synthetic hydraulic fluid for the money? #32
Dear KMA,
The green series 4XX don't have integral hydraulic brakes, which simplifies the fluid demands. I think you have quite a bit of freedom to choose.
All the best,
Peter
KMA said:
Thanks Peter.
   / "Best" synthetic hydraulic fluid for the money? #33
ponytug said:
Given the wetbrakes and gearotors in the 14XX and 18XX series, I wouldn't rush to use additives in those PTs.
All the best,
Peter
Peter,
My 1845 uses a dry brake system. The rotor is mounted external to the wheel motor. My understanding is that all 1800 series units use this system with the Brake Tender (TM)
   / "Best" synthetic hydraulic fluid for the money? #35
   / "Best" synthetic hydraulic fluid for the money? #36
My bad! Ouch 2 for 2.
All the best,
Peter
Bob999 said:
Peter,
   / "Best" synthetic hydraulic fluid for the money? #37
The problem with wide viscosity range oils is that the additives that give the high viscosity range break down under high shear conditions so you often want the narrowest range you can get away with. In some cases, that needs to be a wide range.
Ken
   / "Best" synthetic hydraulic fluid for the money? #38
Ken
On the bright side there's not allot of shear points in a hydraulics's only system. Mainly (depending on pump style) the hydraulic pump, unlike a engine that has multiple points that can shear the oil down over time.
   / "Best" synthetic hydraulic fluid for the money? #39
Hey DieselPower! Nice to hear from you. Just goes to show my ignorance. I would have thought that the close tolerances in a hydraulic system combined with high pressure and flow would have caused shear.
Ken
   / "Best" synthetic hydraulic fluid for the money? #40
Actually when you think about it there are less places to shear in a hydraulic system. The hoses don't, cylinders don't, pumps and wheel motors may a little but the tolerances found there are not as tight as you would in a modern gas or diesel engine. Tolerances in modern electronic HUEI injector's are measured in the microns where the tolerances in a pump are in the thousandths.
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
10' CONTAINER (A52706)
2017 Kubota M7-151 Premium MFWD Tractor (A55314)
2017 Kubota M7-151...
