"Best" synthetic hydraulic fluid for the money?
   / "Best" synthetic hydraulic fluid for the money?
DieselPower,
Thanks for your input!
Hopefully this isn't an inappropriate question (since I believe you represent the TRC UTF Red product in my original post), but how do you feel about an additive package specifically for motor oil used in hydraulic applications? Do you feel it could help? Does a product like this exist? or would one of the existing products intended for hydraulic oil work for motor oil? Sorry for all the questions... :(
Thanks again for everyones's help.
   / "Best" synthetic hydraulic fluid for the money? #43
MossRoad said:
What causes shear?
Shear force, is a mechanical term that has to do with the force of flowing liquid on it's boundaries, taking into account, pressure, and viscosity. Pump design has a lot to do with shear force.
   / "Best" synthetic hydraulic fluid for the money? #44
Just some more data.
[edit] Shear Stress in Fluids
A viscous fluid (including air and water) moving along a solid boundary will incur a shear stress on that boundary. The no-slip condition dictates that the speed of the fluid at the boundary (relative to the boundary) is 0, but at some height from the boundary the flow speed must equal that of the fluid. The region between these two points is aptly named the boundary layer. The shear stress is imparted onto the boundary as a result of this loss of velocity .
   / "Best" synthetic hydraulic fluid for the money? #45
KMA said:
DieselPower,
Just some data for your consideration.
Factors in hydraulic oil selection - Pit & Quarry
J_J said:
Thanks JJ.
Since we've been discussing "shear", here's a section from the article you linked:
In choosing a variable temperature hydraulic oil, operators should ensure the fluid has a high shear stability (the polymers' resistance to stress, which can break the molecules and reduce the viscosity of an oil at operating temperature), as well as excellent hydrolytic stability, which reduces the impact of unavoidable water condensation in machinery after shutdown, helping to reduce wear and corrosion.
"The true test of a good variable temperature hydraulic oil is finding one which offers a wide temperature range as well as other key performance features such as excellent shear and hydrolytic stability," Tavcar said. "Only by choosing a product that performs well in all areas will you be able to reduce downtime and maximize productivity."
Good stuff. To maximize the time between hydraulic oil changes (assuming it is not getting too "dirty" from use), we should choose an oil with "excellent shear and hydrolytic stability", since it would combat viscosity break down and condenstation.
Was poking around and found a fairly long and detailed article regarding engine oil performance in Alberta Canada:
http://www.fireblades.org/forums/ho...emi-synthetic-oil-for-929rr-2.html#post439116
I didn't get through the whole thing, but the following may be interesting to all you Mobil 1 fans out there (text discusses the 5w30 product):
Group-IV/V Blended Basestock Engine Oils:
As a comparison, Group-IV/V Blended based engine oils categorically outperform Group-I solvent extracted lubricants by 150% but differ in their application for straight PAO and PE, and Di-Based Ester lubricants.
This is the only class of engine oils to fully meet the Central and Southern Alberta 70 deg C ambient temperature differential requirement, in a single viscosity grade better, in this respect any other engine oil subsequently, free of any seasonal temperature range planning.
The only product in this category is Mobil-1, a severe service lubricant approximately equal in performance with AmsOil and Redline - unlike these two products, it is not approved for extended drain intervals, and due to its lower kinamatic viscosity numbers, is suitable only for light duty applications. We advise against the use of Mobil-1 in light truck engines in medium duty applications Redline, Amsoil or selected HD Engine Oils are better choices.
Make no mistake - this is an exceptional product; fabricated completely without viscosity indexing polymers, from premium Polyalphaolefin, Di-Ester, and Alkalated Napthalene blendstocks. It has the highest stay-in-grade properties of any lubricant on the market, has step-out high temperature shear stability, and despite its relative light kinamatic viscosities; has been proven to deliver engines through the 350,000 km without ANY measurable wear - and tested to 1,000,000 km on European Engines without catastrophic or terminal engine failure!
This is our first choice in passenger and performance car engine oils it comes very close to being the universal application engine oil suitable all passenger vehicle and many light truck / SUV applications (where the duty cycle is light).
Mobil 1 5w50 might be a good solution in my PT422 for extended temperature range applications, but the "kinematic viscosity cSt @ 40º C" seems pretty high. Probably not a big deal, but I'm assuming this suggests its ability to flow at colder temps is more comparable to a "10w" oil. Not sure though. Actually, having a higher kinematic viscosity to start may ensure it remains high enough over extended drain intervals when exposed to shear stress and viscosity breakdown. (<- tried to use all the fancy terms I learned in one sentence... :p ) The right oil, coupled with an effective, low-cost and easy to build "filter cart" (designed by someone on this forum?), maybe we could extend hydraulic changes and reduce operating costs.
Either way, I'm still trying to get an answer on whether a hydraulic type additive package would make sense in this scenario. I'll post up if I find out anything interesting.
Thanks.
   / "Best" synthetic hydraulic fluid for the money? #48
However you decide to go, get a quote from AMSOIL before deciding against it -- I found the prices quite competitive with Mobil 1... and the specs I was concerned with (viscosity and shear resistance) seemed better than the Mobil 1. Note that I used AMSOIL oil, not their hydraulic fluid. All that evaluation is described somewhere back in the archives here in TOO MUCH detail...:p
KMA said:
A separate additive package is an interesting idea... could it be possible to use dino or synthetic 10w40 motor oil and treat it so it has many of the benefits of UTF type hydraulic fluid? (potentially at a significant cost savings)
If theory, we could choose our own multi-viscosity oil that matches our climates and operating temperatures, and mix in additives to improve corrosion and wear, hopefully helping to prolong pump and hydraulic system life.
I found this product after a short search:
H-ZOL Synthetic Hydraulic Oil Fortifier - SFR Corporation
I sent an email to SFR regarding their H-ZOL product combined with motor oil as hydraulic fluid. Here's the response:
roberts@sfrcorp.com said:
Our synthetic H-Zol is the proper product at 1 ounce per quart of hydraulic oil. It meets most all manufacturers warranty specifications. There is no harm just do not over dose as hyrdostatic systems can slip if you went crazy and added way too much product. Use 4 ounces per gallon of hydraulic fluid. Let me know if you have any other questions.
Maybe this option is cheap enough to be worth trying?
Also, I think I may be swinging back towards an oil like Rotella T 5w40 Synthetic. I think Mobil 1 and Amsoil are great products, but come at a significant cost increase. I've used Rotella T in ATVs and motorcycles and it always worked great, especially in the cold weather. (not very scientific, but it's something I guess)
Thanks.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
Has charger with it. (A51694)
Has charger with...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
