Best way to refill 1lb propane bottles
   / Best way to refill 1lb propane bottles #31
I have told this story a few times but worth repeating here, my BIL used to be a safety inspector and found a factory worker had welded a handle onto an acetylene bottle to make it easy to handle, the torch was connected to it at the time and for some reason it did not explode, I remember one that did explode, we were at home and it was about 3 miles away and we certainly heard it and the windows shook.
   / Best way to refill 1lb propane bottles #32
I wasn't joking about the acetylene tank. I still have the brazed up, cobbled together hose. Is there anything much more explosive than acetylene? A friend put some in an old dishwasher and ignited it. Ended up with his brains showing. First ER declared him too far gone, but his Dad insisted he be flown elsewhere and he survived. I don't know if they still have that dishwasher door, but it was bent into a V where it struck my friend.
   / Best way to refill 1lb propane bottles #33
I remember years ago the refillable tanks were all replaced with new tanks which had a mechanism to prevent overfilling. Also, if they were turned up-side-side -down, a valve would prevent gas/liquid from escaping. Is that correct???
   / Best way to refill 1lb propane bottles #34
My setup was inspired by this guy's website posted many years ago. I already had a 20lb tank to disposable hose adapter so only had to make his female disposable to female disposable with a valve in between. A local farm store had those fittings marked down so big time score there. I was just about out of throwaway tanks and was going to just use my Flame King when my neighbor gave me four brand new ones for doing some wiring for him. The throwaways will leak after awhile and then it's in the trash.
   / Best way to refill 1lb propane bottles #35
Acetylene will not explode under low pressure at normal temperatures. However, it becomes unstable and spontaneously combustible when compressed to a pressure over 15 psi. Beyond 29.4 psi, it becomes self explosive, and a slight shock may cause it to explode even in the absence of air or oxygen. Since acetylene is shock sensitive and explodes above 30 psi, cylinders of acetylene contain acetylene dissolved in acetone, which lowers the danger of storing acetylene under high pressure. Acetylene cylinders are not hollow. They are packed with porous rock or crushed firebrick that is saturated with acetone. Acetylene happens to dissolve readily into acetone, and the dissolved gas is no longer in contact with gaseous O2, which does not tend to dissolve in acetone, and therefore is not as prone to decomposition by O2. The porous rock helps by minimizing the free volume of the cylinder, cooling and controlling any thermal decomposition before it gets out of control. Each decomposition of acetylene gives off heat. Acetone is capable of absorbing acetylene to approximately 25 times its own volume. Incidently, placing acetylene cylinders on their sides can cause the acetone and binders to dislodge. The result may be the formation of an acetylene pocket that is subject to polymerization and the possibility that liquid acetone will be released into the regulator. If storing upright is not possible, it is recommended that the cylinder be placed upright and left to stand for one half hour before using, although I read somewhere else that it should be standing upright for a period of eight hours. Restoring to the upright position allows the acetone to settle to back to the bottom of the cylinder, which in turn would prevent liquid acetone from running through the regulator. Anyway, as far as your pressures and limits on tip sizes 3 and above, the Victor chart I have shows that for welding and multi flame heating nozzles using acetylene, the acetylene pressure range for a #3 and above tip is 3 psi minimum, and 6 psi maximum. The acetylene ranges on the chart go from 3 psi minimum to 15 psi maximum, for material thicknesses of up to 1/32" to 4". Incidently, the "cutting with acetylene" chart shows ranges of 3 psi to 15 psi.
   / Best way to refill 1lb propane bottles #38
Nice when an "EXPERT" chimes in. I am surprised you don't hear of many accidents considering their widespread use.
I don't have a headache rack on my truck making transporting them upright difficult and even if possible, subject to curiosity of the authorities.
Do they make refillable propane in the conventional long cylinders? They ate easier to keep on a machine in the winter.
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
