Best way to support rear of trailer....
   / Best way to support rear of trailer.... #31
This is what I did. Works for me. As you can see. It uses a pin to attach and while I could just rotate it and leave it in place I choose to put it in my tounge box where I store my chains and boomers. <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/442112-best-way-support-rear-trailer-tmp_15685-2015-09-26-15-a"/>
FYI
I have seen the back of the trailer bend when only using one support in the middle like that if the load is heavy.
   / Best way to support rear of trailer.... #32
I welded jacks onto the rear of my equipment trailer:
I use jack stands but I like this idea
   / Best way to support rear of trailer.... #33
I've seen trailers bend in the middle because jacks were welded on the outside frame. The best thing is place blocks or jack stands under the trailer where the ramps are placed.
   / Best way to support rear of trailer.... #34
I welded perforated square steel tubing to each rear corner, and welded a foot on a second piece the next size down, so they slide in and out with 1" adjustment increments.
I think they're 1.25 and 1.0 inch. Push a clipped hitch pin through. They handle by BX24 fully loaded with no problem. Leave a two inch gap to the ground when setting them down.
   / Best way to support rear of trailer.... #35
I have tried Jack stands,scissor jack,bottle jack and 6 x 6 blocks. I load and unload several times a day and I have decided that blocks are best since they are cheap and fast. I attach a 2 x 4 to the side and store it in the stake pocket.
Awesome.
Brent 640 Gravity Wagon (A50775)
Brent 640 Gravity...
2006 SHOP BUILT 130 BBL STEEL VACUUM TANK TRAILER (A55745)
2006 SHOP BUILT...
2015 Dodge Grand Caravan (A47477)
2015 Dodge Grand...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2008 New Holland B110 MFWD Loader Backhoe (A55302)
2008 New Holland...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
