Blew up my new snowblower
   / Blew up my new snowblower #41
I'm not going to pursue a warrenty claim.
1. Because it was my own stuipid fault:rolleyes:
The first post i read that described the damage i thought shear pin? but then right after that thought was "owner replaced shear pin after shearing off the first dozen" = owners fault = expensive lesson most owners have to learn on there own.
Hope you get it running quick.
   / Blew up my new snowblower #42
Mike, I now see that you did a complete teardown as I had suspected. Man, you really had the issues. You inspired me to check everything - I think I am in good shape. Did you ever add the rubber squeegee to the fan blades?
   / Blew up my new snowblower #43
I have to ask you, what grade shear bolts did you put into your two drive shaft shear locations? They should have been grade 3 bolts. If that was done you never would have the problem you have now. Some how you or someone else put a higher strength bolts into those locations which then did not shear at the correct Lbs of force to save your gear box and shafts from harm...
   / Blew up my new snowblower #44
Always good advise to ensure that the shear bolt grades are correct. But, I would imagine he has fixed the problem, since the last response date was in 2009.
I almost forgot.... :welcome: to the forum.
   / Blew up my new snowblower #45
This thread is 4 years old, so don't expect an immediate response (if you get one at all).
Don't be embarrassed...we all do this on occasion.
LOT: Shop Tools: (2) Sets of Truck Ramps, Pittsburg Creeper, Step Stool, Road Cones, Rolling Stool (A59076)
LOT: Shop Tools...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
SNAP ON 3/8" BATTERY CHARGER, IMPACT GUN W/ CHARGE (A58374)
SNAP ON 3/8"...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
1998 CAT 140H Motor Grader (A59213)
1998 CAT 140H...
(2) RATCHET STRAPS & 1/2" CHAIN (A58374)
(2) RATCHET STRAPS...
