Block heater trips breaker
/ Block heater trips breaker #1
JMarchant
Littleton, MA
JD 301A
Hi - I have a John Deere 301A with a block heater. Sometimes it will heat the block without problems but most of the time it trips the breaker within 10 seconds or so. The heater has about a 6' cord and I'm using a heavy duty 8' extension cord. Do you think the cord is the problem? I was thinking about installing a new receptacle so I could plug the heater in directly - do you think that would help? Thanks
/ Block heater trips breaker #2
I shouldn稚 trip. The more powerful block heaters are 1500w which is about the same as a hairdryer. More than likely though, yours is 400w. Have you checked to see what else is on the circuit?
/ Block heater trips breaker #3
Breakers deteriorate over years. How old is your wiring?
Most home circuits are 15 amps, so a 1,500 watt load is near max with a NEW breaker. Start up surge requires more power than later run.
If you install a new, more convenient receptacle be sure to include a GFI so you do not electrocute yourself.
/ Block heater trips breaker #4
1500 Watts is 12.5amps on a 120v circuit, so that in and of itself won稚 likely trip it, but it doesn稚 leave a lot of room for anything else to run a 15amp circuit. But like I said, you probably have a 400w heater which is only 3.3 amps.
/ Block heater trips breaker #5
Try plugging in another high-wattage item, like a hair dryer, and see if it still trips. Try plugging in block heater to a different circuit, and see if the different circuit trips... isolate the issue using the process of elimination.
/ Block heater trips breaker #6
I would start by plugging it into another circuit. Preferably one with a gfi. If it pops the breaker then the circuit is overloaded. If it pops the gfi then there is a short in the heater and/or it痴 power cable.
/ Block heater trips breaker #7
You might able to check the resistance in the heater element. Higher reading probably tells you it not good. I would think it's going bad.
Thanks everyone,
The wiring is new and this is a dedicated circuit. I tried a new 20amp breaker - no luck. I tried installing a different receptacle - no luck. When I plug in a 1750 W heat gun, it works fine. When the block heater causes the trip it takes 10s or so to happen which seems strange (if a short I would think it would trip immediately). The heater is new last spring. Very strange!
/ Block heater trips breaker #9
Can you replace just the cord on the heater. Least that would rule that out.
/ Block heater trips breaker #11
It doesn't look easy to get into the heater to replace the cord. Yes the breaker is GFI. Maybe just time to buy a new heater?
/ Block heater trips breaker #13
I had the same issue on a newer 20 amp circuit. Even drove to my neighbors new shop. same thing. We pulled my heater out of the hose and the element was just hanging there. Installed a new heater and all is well.
/ Block heater trips breaker #14
It sounds like the heater or the cord is your problem. You should be able to replace either individually. The cord can crack or split causing a trip, or the resistance wire can burn through to the outer tube also causing a trip.
/ Block heater trips breaker #16
Now that sounds Genius. Never thought to troubleshoot that way.
/ Block heater trips breaker #17
Loose connections on outlets and circuit breakers can cause breakers to trip. Arc fault protection. All it takes is someone not tighten a connection. Since he replaced outlet and breaker, not the problem. Most likely problem is that the heater warms up, expands and and shorts out. It will test good with a meter and will only fail when it heats up. Replace the heater.
/ Block heater trips breaker #18
Actually, if it pops the GFCI then there is a ground fault. A short will pop the breaker.
/ Block heater trips breaker #19
A small short that is insufficient to pop the breaker will trip the GFI. That could be a short to neutral or a fault to ground because the gfi monitors the load across hot to neutral and trips if there is a variance. These are super sensitive and will trip before a breaker will.
So yes, I agree you are correct, but the real world dynamics of how they work allow you to investigate as I stated.
/ Block heater trips breaker #20
What happens when it pops a groundfault breaker? Is it a short or ground?
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
72in Bucket Skid Steer Attachment (A59228)
72in Bucket Skid...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
Engine (A59228)
Engine (A59228)
