Block heater trips breaker
   / Block heater trips breaker #1
JMarchant
Littleton, MA
JD 301A
Hi - I have a John Deere 301A with a block heater. Sometimes it will heat the block without problems but most of the time it trips the breaker within 10 seconds or so. The heater has about a 6' cord and I'm using a heavy duty 8' extension cord. Do you think the cord is the problem? I was thinking about installing a new receptacle so I could plug the heater in directly - do you think that would help? Thanks
   / Block heater trips breaker #2
I shouldn稚 trip. The more powerful block heaters are 1500w which is about the same as a hairdryer. More than likely though, yours is 400w. Have you checked to see what else is on the circuit?
   / Block heater trips breaker #3
Breakers deteriorate over years. How old is your wiring?
Most home circuits are 15 amps, so a 1,500 watt load is near max with a NEW breaker. Start up surge requires more power than later run.
If you install a new, more convenient receptacle be sure to include a GFI so you do not electrocute yourself.
   / Block heater trips breaker #4
1500 Watts is 12.5amps on a 120v circuit, so that in and of itself won稚 likely trip it, but it doesn稚 leave a lot of room for anything else to run a 15amp circuit. But like I said, you probably have a 400w heater which is only 3.3 amps.
   / Block heater trips breaker #5
Try plugging in another high-wattage item, like a hair dryer, and see if it still trips. Try plugging in block heater to a different circuit, and see if the different circuit trips... isolate the issue using the process of elimination.
   / Block heater trips breaker #6
I would start by plugging it into another circuit. Preferably one with a gfi. If it pops the breaker then the circuit is overloaded. If it pops the gfi then there is a short in the heater and/or it痴 power cable.
   / Block heater trips breaker #7
You might able to check the resistance in the heater element. Higher reading probably tells you it not good. I would think it's going bad.
Thanks everyone,
The wiring is new and this is a dedicated circuit. I tried a new 20amp breaker - no luck. I tried installing a different receptacle - no luck. When I plug in a 1750 W heat gun, it works fine. When the block heater causes the trip it takes 10s or so to happen which seems strange (if a short I would think it would trip immediately). The heater is new last spring. Very strange!
   / Block heater trips breaker #9
Can you replace just the cord on the heater. Least that would rule that out.
   / Block heater trips breaker #11
It doesn't look easy to get into the heater to replace the cord. Yes the breaker is GFI. Maybe just time to buy a new heater?
   / Block heater trips breaker #13
I had the same issue on a newer 20 amp circuit. Even drove to my neighbors new shop. same thing. We pulled my heater out of the hose and the element was just hanging there. Installed a new heater and all is well.
   / Block heater trips breaker #14
It sounds like the heater or the cord is your problem. You should be able to replace either individually. The cord can crack or split causing a trip, or the resistance wire can burn through to the outer tube also causing a trip.
   / Block heater trips breaker #16
Now that sounds Genius. Never thought to troubleshoot that way.
   / Block heater trips breaker #17
Loose connections on outlets and circuit breakers can cause breakers to trip. Arc fault protection. All it takes is someone not tighten a connection. Since he replaced outlet and breaker, not the problem. Most likely problem is that the heater warms up, expands and and shorts out. It will test good with a meter and will only fail when it heats up. Replace the heater.
   / Block heater trips breaker #18
Actually, if it pops the GFCI then there is a ground fault. A short will pop the breaker.
   / Block heater trips breaker #19
A small short that is insufficient to pop the breaker will trip the GFI. That could be a short to neutral or a fault to ground because the gfi monitors the load across hot to neutral and trips if there is a variance. These are super sensitive and will trip before a breaker will.
So yes, I agree you are correct, but the real world dynamics of how they work allow you to investigate as I stated.
   / Block heater trips breaker #20
What happens when it pops a groundfault breaker? Is it a short or ground?
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2019 GALYEAN...
