BOX BLADE :: PHOTO comparision of brands
   / BOX BLADE :: PHOTO comparision of brands #51
Here's a series 25 LandPride box.
   / BOX BLADE :: PHOTO comparision of brands #52
Another shot
We haven't torn it up with the 40D yet.
It's great in combination with the wheel weights for counterbalance when working with the grapple.
   / BOX BLADE :: PHOTO comparision of brands #53
Thanks guys for all the great pictures. It will be next year before I can convince the boss to let me buy a box blade. This thread will be a real time saver then /forums/images/graemlins/grin.gif
rpeter . . . based on the posts, you can see that there is some bias in favor of "captured" lower link pins. For the most part, only light duty models do not have this feature.
Weight is also important with a box blade, within any given size range, the more weight the better. For example, MIDWEST makes a 15-series box blade and a 20-series box blade, both are available in a 48" size. The 15-series is sold for Sub-CUTs and the 20-series is for CUTs, the weight difference between the 2 blades of the same brand is nearly 100# with the 20-series being heavier.
I like the side plate shape of the Midwest brand blade, but really it only offers a minor advantage over the designs with a clipped corner. I believe some of the Gannon blades (made by Woods) also have the same side plate shape that Midwest has. High on my list of desireable features would have to include easy to adjust scarifier teeth. I want to adjust everything without the use of tools and I also want to be able to adjust things while wearing gloves, even I don't always wear gloves, if the parts are big enough to grab with a pair of gloves on, then they are typically easier to engage/disengage.
For what it is worth, I bought a model BB20-48 48" Midwest this spring. I was quoted $400 from one dealer, $420 from another. If I recall correctly the Buhler/Farm King 48" BB was quoted at $435.
   / BOX BLADE :: PHOTO comparision of brands #55
Woods Equipment also makes a rollover boxblade. Looks almost identical to the Bush Hog model.
Bush Hog model attached.
   / BOX BLADE :: PHOTO comparision of brands #58
   / BOX BLADE :: PHOTO comparision of brands #60
Not for sure, but would imagine somewhere between $3,800 to $5,000. I based these numbers on the fact that the heavy duty Land Pride hydraulic HR/HRL35 series is $3,000.00 and the Gannon model weighs 600 more pounds.
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
1268 (A50490)
1268 (A50490)
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
