Box blade
/ Box blade #52
I bought my 5' box blade from Tractor Supply for about 500 bucks. I used it to clear and smooth some ROCKY land and hit stuff that stopped the Kubota L3400 dead in its tracks going down hill several times. From what I have read I may have just been extremely lucky it held together but it did. Other than that, post #5 of this thread sums up what I had to add.
/ Box blade #53
Shorten the top link so the points of the rippers will dig in more. Lengthening is the opposite of what you want.
/ Box blade #54
+1. Also, if your ground is very hard like mine, as someone else mentioned, you may need a good rain to soak in and soften it. During our dry summer months, my 720# ROBB will just drag across the top of the soil/rocks. If it were heavier I would have better luck at these times. Weight and the angle of the scarifiers are key.
/ Box blade #55
+1. Weight and the angle of the scarifiers are key.
I agree. The width of the implement doesn't mean a thing if it's not engaging the ground right. Next time you see a box blade being used, check to see if it has additional weight piled on top of it. Most of the ones around here do.
rScotty
/ Box blade #56
Agreed. You can also raise every other shank to increase pressure on individual teeth should help with ground penetration
/ Box blade #57
the only way to have box scraper is with top and tilt and hydraulic rippers! once you have it you will never go back to the Other way
/ Box blade #58
Yep. I have TnT and makes most any 3PH attachment a breeze to operate. And love the ROBB with no need for adjusting when changing from scarifiers to blade ops and back.
/ Box blade #59
Yep. Thousands of dollars later.
2020 John Deere 26G (A60462)
2020 John Deere...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
DOOSAN 5K FORKLIFT  G25P-5 (A60736)
DOOSAN 5K FORKLIFT...
Giyi LS43 QA Log Splitter (A60463)
Giyi LS43 QA Log...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
