Bridge#2
/ Bridge#2 #142
How did humankind ever get things built before rafts of college boys with their slide rules and calculators?? I just don't know! Oh wait, I do know... They used good old fashioned common sense and overbuilt from there. Just like the OP did here!
Ever wonder why old structures survive, and some modern ones that are only built to design specs don't??
Overbuilding!!
Things were built far beyond there design limits for safety's sake, because folks didn't have the answers, and college educated engineers to back them up.. Today, structures a built closer to the edge, and judging by the bridge failurse we've seen lately, I think I'd prefer to put my trust in old, seat of the pants technology over the handiwork of the college boys with their degrees hanging on the wall.
/ Bridge#2 #143
Your bridge came out great. Very well thought out and done. I'd cross it anytime. I get a kick out of all this engineer stuff. They can and do some great stuff. We have engineers at work who can tell you all sorts of stuff, like the world is black and white. We also have some guys without college degrees that get stuff done when the "theory" just doesn't work. What they lack in formal education they more than make up for in real world experience. I can't tell you how many times we've told a new engineer that something wouldn't work only to have them go ahead and do it anyway. I guess they have to learn somehow. I'm not knocking engineers. We've had some great ones. But the real world isn't all numbers and calculations. I know of many similar bridges built by individuals that have been around forever and take higher loads than his tractor. And history is full of engineering disasters. And lest we forget, a lot rests with who builds the bridge. The best designs executed poorly can be just as bad. My .02.
/ Bridge#2 #144
I still like how we trying to compare the OP's bridge to something commercial, that carries 10's of thousands vehicles over it every day. We have an over pass in town that was built in the last 15 years. In my book that's a brand spanking new bridge. Yet if I'm stopped in traffic in the middle of the bridge waiting to make a turn I can feel a good deflection as the cars and trucks roll by.
Wedge
/ Bridge#2 #146
The 1/8 inch deflection is not what I was concerned about. Remember the Oakland Bridge in California that was closed this weekend? Did you see the Dog Bone Link that cracked at the Eye? That crack was the result of stress-concentration as opposed to average stress. That type of crack starts at the inside of the hole [a point of discontinuity] that the link-pin secures and works its way outward.[ first discussed in 1864 by Barre de Saint-Venant] Now that bridge and its components are many times stronger than it has to be [safety factor] and that link could have completely failed, other links in the catenaries would have safely taken up the extra load. Drill holes in the wrong place and you setup a very local overload that will fail some day. I could bore you for hours with the details of Mores Circle, Dynamic and repeated loading, etc.
Bottom line is, Buggyman ends up in the ditch crushed with the tractor on him.
PS, not kidding. :eek:
I knew that would get you fired up. But do realize I agree with you about punching holes in the wrong places. Bore me all you want.
/ Bridge#2 #147
If a guy looks at a very, very small probability of failure with fear he will never get anything accomplished.
Almost every part or system on an aircraft is proven that it will fail at some point. When that probability is below an acceptable level is it fine.
If Transit's logic of "it just takes one time" was the golden rule of aviation there is not an aircraft in existence that would be allowed to fly.
I am an engineer in the aircraft industry and I will be the first one to tell you that common sense is the best quality to have in designing anything.
/ Bridge#2 #148
some suggestions i noticed for the next one that is built.
instead of drilling ten thousand holes in the I beam for attachment of deck material. Instead bolt single 2x ontop of the beam with a bolt every few feet. then lagbolting or screwing the decking material to the top of that material.
i curious if you budgeted your build. did you price out any other options/variants?
For instance the second span of 10' looks as if a small section of retaining block could have been layed and that portion back filled with dirt/gravel eliminating that section of "bridge" leaving the larger 25' span. At which point many people (myself included) have discussed useing old flat bed semi or the like for small span bridges. For someone who would have actually DONE it, im curious if you spent any time investigating it.
/ Bridge#2
If you look back at the build, that is pretty much what i did, i used 4x4's instead of 2x4's but the same idea. I just couldn't not tie-in the i-beams, for my own overbuilding ego...its hard to explain..maybe i have a drilling fetish...lol. In my mind, bolting the slats directly to the beams makes me feel safer when i cross it with the K. I know that prob. don't make it stronger...it just makes me feel better. As for the budget, i really didn't set a price range, i knew it would be costly, and it cost more than i thought (as everything does). Again, if you look back at the start, and the lay of the land, backfilling the 10 foot section was really not an opition...I think my photo's are lackluster at least. The flat bed trailer is a great idea...I barely had enough room to get a single i-beam to my location. I did put quite a bit of thought into this..and yes i prob. spent to much and didn't think of everything.. I kinda went by my seat of the pants on this, as i do most things...Think of all them stress-fractures on the semi trailers...if i could have got one cheap, and had the room to move it to my place...SOLD.. The bottom line is, do you feel safe crossing it...I do. I'm happy with it.
/ Bridge#2 #150
Intresting. From this photo (and others like it)
it makes it look as if only a small section of retaining wall would need to have been built with a total elevation of no more than about 3' (useing your peer as the main headwall)
regardless the finished product is impressive!
/ Bridge#2 #151
Please let let me know whose planes you work on, if you are designing with "common sense" and not "engineering principal" I would like to avoid them. ;)
I'm tired of hearing the term "common sense", it is easy to use and throw around when you want to mock someone else's thinking but can you define it? Is it something we are born with or do we get it by belonging to a particular political party or geographic area of birth? Everything we know as a human being is learned, there is no such thing as "common sense", a better term would be "poor judgment".
"Common sense" used to be that smoking wasn't harmful, learning has thought us to believe differently today.
/ Bridge#2 #152
Thanks for the reinforcement Turbo. I do not want to pick on someone with common sense. Catch you later with some photos.
/ Bridge#2 #153
If you can't grasp the concept of "common sense" you must not have it.
Maybe you and Transit can find a support group for people that lack "common sense".
/ Bridge#2 #154
Yep, that's me, the good ole "don't know to come out of the rain" me!
All that the college learnin' ain't as good as some home spun common sense.
Must be I was just lucky in starting and running two successful businesses, couldn't have been all those worthless engineering and business classes. Oh well, better to be lucky then "common sense" smart I guess.
/ Bridge#2 #155
Seems there's a few feathers ruffled here.. or egos bruised.
Pity we can't just all tell the OP what a great job he did and be done with it..
Ahhh well. That's the internet for 'ya.. Where everyone is an engineer, and everyone knows better... Too bad!
The bridge looks great to me, and if my property had an area that needed one, I'd be proud to call that bridge my own... Even without the blessings of the "engineers"...
/ Bridge#2 #156
Hey, wait a minute... I gave it a blessing:cool:
/ Bridge#2 #157
No ego's bruised here (unless your's is) I think the OP did a great job and for his use it will most likely be fine, holes and all! Can you show me where I critiqued the OP?
My comments were directed to the "aerospace engineer" that suggested "common sense" trumps science. If my engineers came to me with a design based on common sense and not scientific study I would show them the door.
/ Bridge#2 #158
No ego bruised here either, but I didn't trot out my qualifications..i.e. all the successful business ventures, hours spent toiling at engineering and business classes..
Nope, my ego isn't bruised! I spent an entire career actually building what the college boys dreamed up.. Where the rubber meets the road. And, I could always tell a smart engineer from one less so.. The smart ones would listen to, and heed my advice and design changes.. The less than smart ones?? Well, they were great also! I got a lot of overtime making things they designed anew, after they could finally see it wouldn't work..
Yup, I made a lot of "time and a half" because of engineers that always knew better.. LOL
/ Bridge#2 #159
Common sense is something you use in Addition to education and smarts, not in place of it. I work for a company making aircraft engine blades and vanes. I inspect gages designed by engineers every day. Some really good, some laughable, if they weren't $30,000 a copy. I respect the engineering profession but like any profession, it has its stars and it's duds. The best engineers understand how things work by getting their hands dirty. We have a few of those. We also have a few that will tell you things must work and they don't. They have no common sense. I've seen some pretty complex gages that could have been done in a much simpler and cheaper fashion. They are engineering marvels,but a little common sense would have saved everyone time and money.
There are many ways to accomplish projects. If that bridge was engineer designed it would never have been built. Too expensive and too complex. The design fee would have been more than the bridge with all those calculations. It's a bridge for a tractor and I think very well done using common sense and his smarts. Would I want him to build a bridge for a 4 lane highway? Not really, But if I ever need a tractor bridge, he's the man.
White 5409 9ft. Disc Mower (A65640)
White 5409 9ft...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
New/Unused AGT Industrial LRT23 Mini Skid Steer (A65583)
New/Unused AGT...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
