Bucket level indicator on 3016
   / Bucket level indicator on 3016 #11
I know this is old post put this is a great simple design - I have the KLM 116 bucket but I believe its identical.
Sure need the level moving snow on rock drives.
Thanks, Tom
you might just have to make the rod and the tube a little longer (or shorter).
   / Bucket level indicator on 3016 #13
Yes I planed on making it longer then cut to level- thanks for the heads up - I presume yours is still functioning correctly ?
works like it was designed to. I'd really miss it if it went away. For snow and other loader work, it makes the job much more efficient.
I put some 'witness marks' on the bolts that I loctited into the pins, just so I could keep an eye on them to catch any loosening. So far no motion at all.
I used blue as that's all that I had, but I don't see why either wouldn't work ok.
   / Bucket level indicator on 3016 #17
works like it was designed to. I'd really miss it if it went away. For snow and other loader work, it makes the job much more efficient. I put some 'witness marks' on the bolts that I loctited into the pins, just so I could keep an eye on them to catch any loosening. So far no motion at all.
I followed Oldpilgrim design and it works great I to would be lost with out it for loader work thanks again oldpilgrim for the design and all your help
Sent from my iPhone using TractorByNet
you're welcome, Ed. Glad it worked for you.
   / Bucket level indicator on 3016 #19
Just have tractor about 2 weeks but wish I had it installed today moving 8" of snow off stone driveway LOL
   / Bucket level indicator on 3016 #20
Ok we are welded up and getting ready to drill pins.
Is there a auto parts spray can match for Mahindra Red ????
Aerway Tillage Tool (A59814)
Aerway Tillage...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59575)
2022 KAUFMAN 2 CAR...
