building a dirt buggy
   / building a dirt buggy #41
I need some ideas now:
last week i sawed some floor boards, and fabricated a piece of firewall to match the original mounting of the pedal tray.
I hung the radiator and battery in the front, just for mockup.
Now i need radiator hoses: i used garden hose once, to replace a cracked cab heater hose in the cab of our 5245. That didnt last long as it couldnt handle the temperature.
The engine is a cast iron block with aluminium heads: Which means i need the original all steel radiator, and an old, higher capacity, all copper Zetor radiator wouldnt work, as Galvanic corrosion would occur between the copper and the aluminium.
Anyways, what will work for water pipes ? Galvanised pipes will propably smudge their zinc coat all over the internals of the aluminium head, which may cause a heat exchange problem between the head and the water.
Stainless pipes are too expensive.
Will standard steel pipes work ? The block is iron too, so i dont expect any funny reactions in the Galvanic chain...
Can i just use steel pipes, or are cast iron blocks treated in any way to prevent rust, that standard steel pipes dont have ?
Or does cooling liquid have a chemical additive to stop internal corrosion ?
   / building a dirt buggy #43
Renze, Most of my buggy experience is in air cooled (VW bug) powered machines with either modified VW beatle pans or custom tube frames so I have little experience with "Camels" (AKA water pumpers) i.e. water cooled buggies. Surely you have access to hoses capable of holding full radiator pressure at temps exceeding automotive cooling system's temps.
If you don't really need the weight up front you can mount the radiator horizontal above the engine and probably find off the shelf hoses that will reach, especially if you join multiple hoses with pipe fittings. Iron or steel pipe fittings isolated from touching dissimilar metals aren't a big corrosion worry. You may be able to find some plastic fittings able to take the pressure and temps.
Dune buggies (especially sand rails) typically run light in the front and can wheelie fairly easy so for that approach radiator in front is not mandatory but don't corner the best too light in front. For good cornering characteristics you need to lean more toward the Baja racer type setup with a better weight distribution and maximum suspension travel.
Just loosing a lot of weight on the car changes the suspension tuning significantly. Whereas critical damping is good for handling you might want to consider some changes. If the donor car was sprung and shocked for average loading then after loosing a lot of weight the springs are equivalent to HD overload springs now and the shocks no longer provide critical damping. I'm sure you know the concept I describe, I'm not taking you to school but just trying to be sure my general idea translates.
Warning technical content follows: There are three possible
damping conditions in your suspension: 1. underdamped, 2. critically damped, and 3. over damped. Critical damping is desirable and with the right shocks the original donor vehicle not overloaded was probably more or less critically damped. Just removing a bunch of weight makes the suspension correspondingly stiffer (more spring constant for the mass) and no longer critically damped. Contrary to popular erroneous opinion more is not always better in shocks or springs. Said another way, right sizing beats random upsizing.
Proper coolants do have anti-rust compounds and you can buy anti-rust additives suitable for adding to standard off the shelf coolants to boost the anti-rust action.
In deep mud fat tires win. Only if the mud is just a layer of "goose grease" on top of good footing do narrow tires have any advantage. I have been stuck in mud when the mud was less than 1/2 inch deep. This with an automatic tranny and a very gentle throttle foot. I couldn't go up a shallow incline in 4x4 with dually 1 ton Dodge/Cumins. I run 245 R19.5 Michelin mud and snow tires. I got out to string out the winch line, noticed the small depth of the mud and just cleaned out in front of the tires with a shovel as the truck was unable to climb the 1/2 muddy ridge and drove right away up the slope. Had I been running stock sized tires I may not have had to get out. I run W I D E tires on my VW based buggy in back and only slightly oversized in front.
Steel pipes? I don't think there would be any problem if you isolate the pipes electrically, i.e. don't let steel pipes touch a dissimilar metal. The anti-rust in the coolant should protect the pipes and you can add extra anti-rust compound if you like. I'm noto aware of any treatment in cast iron blocks to avoid rust beyond the anti-rust in the coolant.
I ran seawater cooled cast iron block and manifold engines as aux power on sailboats for many years. These engines circulated heated sea water throughout the cooling system and were never drained, were always filled with sea water 24-7 except every few years when the boat might be hauled for a repair or painting. A kindler gentler approach is to cool the engine with fresh water with coolant like in automotive service and use a heat exchanger with seawater in one of the circuits to cool the engine. So happened the boats I bought were raw water cooled not fresh. When I sold the last sailboat I had been living on it was over 20 years old and the block was never pulled for maint. IF you have any luck at all you should do well with a good anti-rust coolant.
If you don't like expanded metal in the floor consider louver panels at the locations most likely to collect dirt. You turn the louvers so they don't scoop up mud and dirt inside the vehicle can fall out.
Pat
   / building a dirt buggy #44
dbartman
Can you start another post about how to make the fish-mouth with a chop saw.
Ron
   / building a dirt buggy #45
855Idiot said:
My Buggy was built with an 1982 Subaru 4X4.
Good Luck,
Glenn
Yo, Glen! Nice ride dude. I could sure use something like that as a ranch work vehicle, sort of a go anywhere mini-pickup.
The low mounted side panel beside the driver... If that could be made to fold down like a tailgate to facilitate getting in and out and in and out and... yoiur buggy would be the cat's meow. My currne tbuggy is a Myers Manx type fiberglass body on a shortened VW Bug pan with extensive roll cage for the people and engine. I have a modular soft top for it, removable cloth doors with flexible plastic windows etc. It is OK and lots of fun EXCEPT it is a challenge to get in and out quickly so it is frustrating if you have to get out to open and close fences.
Pat
   / building a dirt buggy #46
Renze,
Try using exhaust tubing (muffler tubes) Get a bunch of straight tubing from a shop, and a bunch of radiator hose elbows. Hose clamp them fromthe engine to the radiator and you'll be all set. If you want to get fancy, flare the ends of the tubes to help prevent the rubber elbows from blowing off and spraying hot coolant!
For the dissimilar metals in your system, try a sacrificial anode. Usually zinc, as the electrical potential is lower than aluminum, it will rot first, protecting your aluminum. Sailing supplies or online would be a good place to find one.
Good luck, you project looks like a ton of fun.
Keith in South Carolina.
   / building a dirt buggy #47
Renze, If you elect to go with sacrificial anode protection (sacrificial zincs) you will want to electrically bond all of the metal that is in contact with the coolant together Including the zinc. Most folks use coper wire for bonding the metal stuff together. Then until you get a handle on the rate of consumption of the sacrificial anode you will want to check it frequently to see how much is left. It may look pretty knarly after it has been in service for a while but you can wire brush it to get the "gunk" off and renew its operation.
I have successfully used sacrificial zincs for decades. Keith gave you good advice as to availability. Ship chandlers are a good source. Given a choice, I'd buy where the commercial fishing boats buy rather than a "yacht Boutique."
Pat
   / building a dirt buggy #48
I think old water heaters also have anodes in/on them somewhere, if you have or know of any laying around.
   / building a dirt buggy #49
Ronbo said:
dbartman
Ron
Give me a couple days, Ron, & I'll do a full photo explanation. Need to find some suitable tube (I think I have some 2.5" exhaust around somewhere) & want to wait for slightly less humid weather.
   / building a dirt buggy #50
Hot water tank anodes are magnesium (aluminum is also available). It's located on the tank top & should be a blank 15/16" hex. Not sure how these would protect aluminum (which would not be found in home plumbing). JC Whitney (jcwhitney.com) sells radiator anodes.
2023 John Deere 333G for Parts (A56435)
2023 John Deere...
2025 AGT MH12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MH12RX...
2025 SF60 60in Hydraulic Forks and Frame Skid Steer Attachment (A56857)
2025 SF60 60in...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
