Bulk Grease Choice?
   / Bulk Grease Choice? #22
Does moly have any disadvantages? From what I've read so far it sounds like the only choice for FEL pivots - which is the only part of my tractor that needs grease more often than every 50 hours (FEL spec is every 10 hours).
   / Bulk Grease Choice? #23
As far as vehicles and tractors go the only disadvantage would be a higher price. There are some special applications in industry that Moly wouldn't be recommended but they are few and far between.
   / Bulk Grease Choice? #24
jeffinsgf,
What bulk grease gun did you get, where did you get it and what did you pay for it?
Thanks.
   / Bulk Grease Choice? #25
Where do you guys buy this stuff? I did a search for the moly 880 and could not find anyone actually selling it - just links to TRC.
   / Bulk Grease Choice? #26
You buy it directly from TRC.
   / Bulk Grease Choice? #27
Who's TRC ?? I feel stupid!!
   / Bulk Grease Choice? #28
TRC = Texas Refinery Corp. There's a link to the grease being discussed in the second post of this thread.
   / Bulk Grease Choice? #29
My Dealer (Pine Bush, Holmes Branch) Recommended that I use Komatsu Moly-EP High Pressure Grease. We have a 2006 BX24 that I make sure to grease often. You've got to use the stuff rated Moly-EP High Pressure for anything that moves on your tractor. The better the grease, the less often you have to get pins replaced.
   / Bulk Grease Choice? #31
sw03, providing a link to an excellent product for information purposes is hardly "pimping", especially considering the large numbers of links that one finds in all the various discussion groups on this site. A question was asked and DieselPower put out an option for consideration.
TRC lubricants are definitely on the high end of the scale as far as quality goes. I can say this about TRC products, they are the best lube products by far that I have found so far!
   / Bulk Grease Choice? #32
I am saying lets see the rawdata from all. So far I have only seen this product on this forum.
Why is is better? Price? Oil Separation? Leakage? Water seperation? washout? Moly %? I see nothing great about it, but maybe I am missing something.
Point was years ago this would be bashing left and right. So, as you stated, why is this the best product out there. IF you do not use it, will your FEL/BH blow up? This is like Chevy vs Ford debate.
   / Bulk Grease Choice? #33
DieselPower has not posted since July and his post in this thread is 2.5 years old. :rolleyes:
   / Bulk Grease Choice? #34
Just like with engine oils, UTF's and gear oils there are many properties that come into play to make a superior lubricant. With grease some of the key features to look for are load capacity, water resistance, cohesive/adhesive properties, compatibility, temperature range based on application and oil seperation characteristics.
Let's start with water resistance. It's fairly straight forward. The greater the resistance to water the better. If it resist water it will repell it forming a water resistant coating on lubricated parts preventing rust and corrosion. The greater it's water resistance the better it can maintain it's load rating when contaminated with water. The best greases can maintain their load rating even in the presence of 20% water. A demonstration I do for water resistance is done on my car or truck side window. I take the competitions grease and smear a little on it (my window that is), take a handfull of paper towels, soak them with water and spray water on the window while I try to rub it off. Eventually I end up wiping off all the competitions grease. Then I stick some of my grease on the window and do the same. All I end up doing is spreading the grease around, you just can't get it off with water and paper towels. You have to use solvent to remove it.
Cohesive/Adhesive properties. This is the "stickyness" of the grease. The cohesive properties is what makes it stringy. The more cohesive it is the more resistant it is to being pulled apart. In other words, it doesn't want to let go of itself. The adhesive properties are how well it sticks to other things, your tractor and you (and much to your wifes dislike your cloths). :) There is a fine line in how cohesive and adhesive a grease can be. I have seen greases that were to cohesive that they actually balled up and fell off on rotating shafts. A properly formulated grease should be just adhesive and cohesive enough that (lets say on a pillow block bearing and shaft) it should be able to form a barrier against contamination/dirt yet resist balling up and falling off. Basically it should leave a ring on the non rotating part of the bearing and the same on the shaft. It more or less forms it's own seal against dirt entry. Cohesive/adhesive greases will also greatly help to reduce grease consumption and actually help to reduce wear. If the grease resist being pushed out, slung off or washed off and stay's in place the next time you have to grease you don't have to use as much. A good grease may cost more but if you only use 1/2 as much where's the savings in the cheap stuff. Also if it is staying where it should, the lubricated part, you reduce wear. When the grease is not cohesive and adhesive enough and is forced out under load there is nothing left to protect the equipment. Where do you want your grease? On the ground or where it should be, in the lubricated part doing it's job.
Compatibility isn't a huge problem but something to watch for. Some grease thickner types are not compatible and when two non compatible greases are mixed the end result is a grease mix with greatly reduced lubricating properties and also tends to become thinner. If switching grease thickner types just lubricate a little more frequently until you get the majority of the old grease purged out.
Temperature range, it's a no brainer. If you are lubricating bearings in a furnace you want a ultra high temperature grease that never melts. In most tractor applications you don't need a ultra high temperature range. Something around a 300 deg. F. dropping point is typically fine for a tractor. You need to watch temperature ranges when you start to get into things like electric motor bearings and disc brake wheel bearings etc...
Oil separation is just what it sounds like, a greases characteristic to bleed/separate oil from the thickener. Ever opened a pail or tube of grease that has been setting for any length of time and seen oil? Picked up your grease gun and seen oil run out the end? That's oil separation. A good grease will not bleed it's oil out of the thickener until it is actually in use where it bleeds out a controlled amount to do it's job, lubricate and can reabsorb any oil that does bleed out. I have pails of grease at my place that have been setting for over 12 years and show no signs of oil separation or cracking/shrinking of the grease. A grease with excellent oil separation properties should in all honesty never go bad setting on the shelf, even 30 years later.
Load rating is a greases ability to protect from wear under extreme pressure/load. The greater it's load rating the more protection it provides at higher loads. If you are lubricating items like FEL's and BH's you want the highest load rating you can get since they place enormous amounts of load on the pins and bushings.
Another option you can get in many greases is the addition of Molybdenum Disulfide (Moly). In applications like FEL's and BH's it is a excellent wear preventative. In these applications even the best grease on the planet will at some point be pushed out. The Moly forms a solid film on parts and acts as a last defense against wear. It is also great at reducing frictional heat. John Deere actually spec's a 3% Moly grease on their excavators. A good Moly grease will have 5% Moly by volume.
I'm sure I forgot a couple of things but its a start.
Informative post on grease characteristics - I just read it. I realize you posted it some time ago. Thanks
   / Bulk Grease Choice? #35
I have been using Chevron Delo Grease #2 for a couple years now, in all that I have. I have seen nothing disturbing as to wear, or the performance of the machinery. I believe in Delo engine oil, and their Tractor Fluid is excellent in my book. HOWEVER, there really are many excellent hi performance greases being sold. Hydrotex had one ---"Parasyn 70", I sure wish I could afford that stuff. You guys need to give at least some credit to yourselves, because I believe that you do grease your machinery, you're not abusers nor are you neglectful.
   / Bulk Grease Choice? #36
TRC makes some great greases and DieselPower provided some fantastic information. Any consideration to Schaeffer's line of grease? The Moly Ultra Supreme has a 5% Moly. The Ultra Red Supreme and the Moly Ultra 800 both meet the 3% moly specification. Of the 3, the Ultra Supreme has the most tackifier and is mostly engineered for heavy equipment in the mining and construction industries. Of the 3, the Moly Ultra 800 is the least expensive and will outlast any Lithium Complex base grease around 2:1, some a little more, some a little less.
In a side by side demonstration performed by my local TRC Rep. The Schaeffer Ultra Supreme had noticably more residue on the razor blade. I have every confidence TRC has superior performance to most greases. Of the high end greases, Schaeffer can defeat the high end prices most of the time.
DieselPower: Your explanations were very informative. Would you be willing to explain what reversibilty is?
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
1968 Oliver Model 1950 2WD Tractor (A56438)
1968 Oliver Model...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
