Which grease for my Yanmar YT235-??
   / Which grease for my Yanmar YT235-?? #1
tjklein
NJ
none
So just got a YT235- I see multiple threads and seems like no clear answer- Was thinking of going with Lucas either the Red and tacky or the X-tra heavy duty grease Is one or the other better OR is there a better choice- thks
   / Which grease for my Yanmar YT235-?? #2
Lots of excellent greases out there.
Lucas is fine stuff.
Use of a quality product at reasonable intervals with provide you with more than acceptable results.
Good Luck!
   / Which grease for my Yanmar YT235-?? #3
If your tractor is new check your manual and go with the spec's
listed so you don't lose your warranty
willy
Willy I see you are a Yanmar guy with the same tractor- mine is a 2021 just got it with 60 hrs- what grease do you use??- thks
   / Which grease for my Yanmar YT235-?? #5
Shell Rotella HD grease is what I use on our SA425 (tractor, loader and 60" mower deck).
   / Which grease for my Yanmar YT235-?? #6
I use TSC synthetic not the cheap stuff and not the most
expensive I get the tubes for the grease gun. My equipment gets greased almost every time I use it so
no worry
willy
2021 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2021 Allmand Bros...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
