LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,214
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
OK, now we are back to you have a gear driven transmission with a mechanical shuttle using a dry clutch.
So we are also back to lubricating the clutch shaft and linkage, then adjusting your foot clutch for an inch of free play.
If you have not adjusted a clutch before free play is the amount of clutch pedal movement before it tightens up and starts to depress the clutch fingers.
So after lubricating the clutch linkage and verifying that it is all free and easy moving, with the tractor off and parking brake set,
reach in with your hand and see how far you can move the clutch pedal with your hand.
Trying to push it down the amount it travels easily is your free play. Also try and lift it or pull it back it should not pull back any.
If it does your linkage needs to be cleaned lubed and freed up before any else is checked.
A regen is when a DPF (Diesel Particulate Filter) has extra fuel injected into the system to burn outside of the engine and in the exhaust to raise the exhaust Temperature high enough to burn off the accumulated carbon build up.
I am not positive but I think your tractor has a DOC (Diesel Oxidation Catalyst) which does not get an occasional fuel added regen but relies on continual exhaust heat to be enough to help it remain clean.
