Burning ULSD in Kerosene Heater?
   / Burning ULSD in Kerosene Heater? #11
You don't want to run kerosene in your tractor.
The intent was to use ULSD in the Kerosun. But the post about the wax content being more in ULSD than in kero, regardless of sulfur content leads me to believe that I'll continue using separate fuels for each.
   / Burning ULSD in Kerosene Heater? #12
The best thing to do is use the right fuel in the right equipment.
Kerosene in the Kerosene heater.
Diesel or HHO in the tractor.
As for the 50/50 mixture of the 2 fuels I might chance screwing up a 200 space heater with it.
No way would I take a chance on destroying a $20.000 tractor with that mixture.
   / Burning ULSD in Kerosene Heater? #13
I was chatting with the guy at the fuel distributor a couple of years ago when Kerosene shipments were on an alotment basis. He confirmed that K-1 (kerosene) and Jet A were almost the same -- Jet A has some additional additives put in it (like water dispersant, anti-corrosion, ... that you would want in Jet fuel but wouldn't need in kerosene for heaters and lamps).
   / Burning ULSD in Kerosene Heater? #14
I heard that old timers mixed kerosene with diesel or run straight kerosene in tractors in really cold climates before the howes, power service was around. I probably would do it in the winter when its 0 or below, but not in the summer since kerosene burns hotter then diesel.
   / Burning ULSD in Kerosene Heater? #15
When I was kid we used to have a cottage by the lake without electric power. Therefore we used wick kerosene lamps (I think we called them storm lamps). When filled with diesel the flame was kind of reddish and didn't provide nice light. It also took for a while before the glass cleared. When filled with kerosene the lamp burned bright yellow giving much better light and it took only short time for the glass to clear up.
   / Burning ULSD in Kerosene Heater? #16
1*I heard that old timers mixed kerosene with diesel or run straight kerosene in tractors in really cold climates before the howes, power service was around.
2*I probably would do it in the winter when its 0 or below,
3*but not in the summer since kerosene burns hotter than diesel.
1*Old timere aren't always rite.
2*Not me because you'd be getting to much Kero in the Diesel due to the mixing.
3*Winter or summer /hotter burning makes no difference.
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A57453)
2016 Hino 195h...
MACK DUMP TRUCK (A59823)
MACK DUMP TRUCK...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
Volvo L306 (A57148)
Volvo L306 (A57148)
2010 Honda Fit Passenger Car, VIN # JHMGE8G28AC003572 (A57453)
2010 Honda Fit...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT2EHFU7070 (A57453)
2014 Freightliner...
