Bush Hog shear pin
/ Bush Hog shear pin #1
ebeacham
Southport NC
TYM 723
I have a 6 ft King Kutter BH that came with a grade 2 bolt as the shear pin. Does anyone know wether or not that is the correct hardness for this application? Sure seems like I go through a lot of them.
Thanks,
/ Bush Hog shear pin #2
Eric,
I can't answer your question, but I'd like to "tag-a-long" a shear bolt question of my own. With any luck, the wisdom of this board will be able to address both issues at once.
In preparation for winter, I checked the 2 shear bolts on my Woods SS60 snowthrower. I figured it's better to get familiar with them now, before they shear and I have to replace them in the bitter cold. Anyway, the manual specifies them as both being 5/16"x1" long bolts. One of them is on the tractor end of the PTO shaft and the other is on the auger chain sprocket.
I removed them both, and sure enough, they are the size specified. However, the PTO bolt is a grade 8 (6 dashes) and the sprocket bolt is a grade 5 (3 dashes). I was expecting grade 2!
My dealer thought that was a bit odd and was going to look into it. While I had the bolts out, I picked up a couple of grade 2 replacements. I wanted Grade 5, but as is always the case, the hardware store didn't have the Grade 5 bolts in that size.
My question: If I use grade 2, could I cause any damage? By my reasoning, I figure they'll shear before the grade 5's or 8's would. If they shear too easily, then I figured I'd try grade 5's, once I pick some up.
But the grade 2's should work in a pinch.
It sort of defeats the purpose of using the same size shear bolt for both applications if you have to keep two different types (hardnesses) of bolts on hand.
Any comments?
And yes, I know, a new snowblower with plenty of spare shear bolts guarentees that there won't be a flake of snow within our property all winter. /w3tcompact/icons/sad.gif
~Rick
/ Bush Hog shear pin #3
yes grade 2 are the right bolts to use.
i made the mistake of just throwing any old bolt in my bush hog and then i hit a stump and wam i busted my ptoshaft up inside the tractor.
breaking the shaft wasnt as bad as putting a new one in.
i had to split the tractor to fix it.
so if i was you i would use grade 2 bolts
/ Bush Hog shear pin #4
Grade 2 are what are specified for my Land Pride rotary cutter and the bottom of my toolkit is littered with evidence that they shear just fine (well part of the evidence...the rest is in the field somewhere).
/ Bush Hog shear pin #5
Just got an SB74-2 blower, posted msg a while ago, seems Woods initially specified a no-name-no-hardness bolt but it has been updated on the parts list to a grade 8 bolt. That's all I know! Maybe a harder bolt fractures more easily? Less easily?
Mike
/ Bush Hog shear pin #6
Mike
You are replying to a 12 year old thread, so I suspect he's got his shear pin issues worked out by now.
FYI, I would never use a Grade 8 bolt for a shear bolt. Most manufacturers specify a Grade 2 it seems to me. Grade 8 seems like a good way to negate the whole purpose of the shear bolt setup.
/ Bush Hog shear pin #7
I had the same problem with a woods BB60. was shearing grade 2 bolts faster than I could change them. I installed a slip clutch using a grade 5 and solved the problem
/ Bush Hog shear pin #8
I would go to a higher grade if it is shearing bolts for no reason (not hitting anything but grass). My BIL had to go to a grade 5 to keep his Fred Cain BH from shearing when engaging the PTO even at an idle. I have seen it shear a GR.2 bolt when mowing light grass and no obstacles. Some shear bolts are just not the right size/type to begin with. Move up a grade at a time till it only shears when it should, like when you hit a hidden object and not when you just engage the PTO.
/ Bush Hog shear pin #9
Maybe this is a timeless topic or maybe all shear bolt issues were solved years ago. Anyway ... using a 4ft John Deere 413 (with no slip clutch) I found the critical factor is the bolt fitting the hole. On my 413 the correct bolt is metric and grade 5 is recommended. When I used an English dimensioned (3/8" or so) bolt that had a little bit of play in the hole it would shear every time I tried to use it. Once I used metric bolts that fit the hole tightly and happened to be grade 5 I have never had a single problem since. I came away with the opinion that a good snug fit in the shear pin hole was at least as important as what grade bolt it was. In my experience only the smaller hogs (being used on smaller tractors) have shear pins instead of slip clutches. I favor using a grade 5 at least if not an 8. However, a grade 2 shear bolt is very cheap. Try it ! If the thing does not become a nuisance by shearing all the time then you have the best protection. If it shears often, go up a grade on bolt hardness but make sure it fits snug first.
/ Bush Hog shear pin #11
It can not be a Bush Hog® if it is a King Kutter.
/ Bush Hog shear pin #12
It can not be a Bush Hogョ if it is a King Kutter.
You're right about that. And it cannot be a Deere if it is a Bush Hog. Keep in mind, nothing runs like a Deere nor smells like a John...
/ Bush Hog shear pin #13
When I called BushHog and talked to their technical folks about the CORRECT shear pin to use for my FIL's new BushHog BH15, they didn't really seem to care much if it was grade 2, grade 5, whatever. From the factory, it had a grade 2, 1/2". I see from their website they are now supplying it with a 8x50mm grade 8.8 metric.
I'd go with what JWR (and others) said; run a snug-fitting grade 2 and if that is reasonably durable, stick with it, but if not, go up to a grade 5 or 8.
- Jay
/ Bush Hog shear pin #14
I agree with JWR on the snug fit, but not about the Grade 8 bolt.
We used to have a cutter with a shear pin hole that had wallered out, which created slack that caused it to shear more often.
Using a grade 8 bolt could cause the shear pin to fail to serve its purpose. I'd rather replace a shear pin than risk damaging the internals of the tractor.
/ Bush Hog shear pin #15
I have a 5 foot King Kutter. I use a grade 2 3.5 x 1/2 inch bolt from Tractor Supply. I probably go through a half dozen a season and I mow a lot. Make sure you are at low throttle when you turn on your pto. You should not shear a pin mowing unless you hit something solid and that should not happen that often unless you are clearing unknown land.I put my shear pin in by hand and put a twist of safety wire on the threads or a strip of duct tape to keep the nut from backing off. It takes me a couple minutes at the most.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2020 DY TP90 TRAILER MOUNTER CONCRETE PUMP (A59905)
2020 DY TP90...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
UNUSED FUTURE FT15 EXCAVATOR (A60430)
UNUSED FUTURE FT15...
