mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,310
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Interesting.
"I've never worked with pre-made panels, but have heard they are faster to install and offer supperior insulation. I didn't realize that the sheething didn't wrap around the corners. Do you do anything extra for this? or is it code as it is?"
Panels are routed for a 2 x 6 walls and 2 x 10 roof. Under load bearing areas it can be double triple or Quad 2 x 6
You still use a lot of lumber with this stuff.
"What is your R value for your walls?"
The Foam itself is 26 walls, 38 ceiling. Supposedly better than conventional as everything is foam sealed and near airtight.
"What type of windows will you use so that you don't lose that R value?"
I'm using triple pane kypton filled u=.2 or better vs. normal energy star on .31. PPG system made in Germany imported and stuck in these windows below with foam filled casing.
Even with all that, that is only R= 5, so you loose out of windows no matter what. you pay for the view.
Tribute Windows - Vinyl Windows by Harvey
With the price of lumber and labor being so low with the economy crashing, for what these clowns charge, if I did it again I'd Stick build. I'll be long gone before I get the energy payback.
Thanks,
Eddie
Eddie see above
mike
