Dmace
Elite Member
I agree they would be close what I don't agree with is Chris' thought that an Ecoboost would "straight get it".jejeosborne said:I will say it again for the forth time, these trucks would be very similar in a drag race. You can continue to disagree based on your bias because you wear only one hat. Please tell me the reason for your strong attachment is because your great-grandfather was Walter Chrysler or you are employed by chrysler. If not, why have they set the hook so deep?
My strong attachment to Chrysler is soley based on the fact that it's the ONLY vehicle I've owned and driven (30 plus owned/ 100's driven) that has been so trouble-free and so able to do anything thrown at it. I've towed with Ford's, Chevy's, Toyota's, etc... and NONE took the load as well as a Dodge truck. The Ford's squatted and ran out of power, the Chevy's brakes sucked, the Toyota's steering and power were useless and every Dodge 1500-3500 gas or diesel always felt the same with any load behind them. I routinely overload my 2003 1500 and haven't even changed the spark plugs in 105k miles...
Maybe some others have had similar results with other manufacturers. To each their own...
If you think those two are the same then I can't help you...jejeosborne said:Oh by the way, I also am still confused on another part of your post after reading it completely, twice. You mentioned: "I'll give you the variable valve timing as not "simple" but it's far from a high compression twin turbo water-cooled engine with direct injection...".
Do you not like diesel engines because they fit this description exactly?
How would you suggest the engine be cooled? Hydrogen, air, freon?
Also, the "water-cooled" was referring to the turbos not the engine but again I'm not surprised you don't get it...
I only use the HEMI for reference as it's the benchmark for all engine comparisons and I know from personal use just how good it is. Look around and every manufacturer and auto magazine compares trucks to the HEMI as it's on top...Diamondpilot said:Do you actually listen to yourself babble? Hemi this, Hemi that.
Speaking of brain washed, " best truck engine to come around since the Chevy 350"Diamondpilot said:I commend Dodge for building a 8 speed, why cant you do the same for Ford building the best truck engine to come around since the Chevy 350?
I commend them for trying but to push it as the replacement for simple V8's and the ultimate working truck engine is rediculous.
It's a strung out V6 that does everything a V8 does but with a ton more parts to fail, yeah thats innovation all right...
So would a twin turbo 4 cylinder making the same power and just 10% better fuel mileage be better than a NA V6...?
