Price Check Buying a used MX5100 - some questions.
   / Buying a used MX5100 - some questions.
Yes LD1, I got two rear remotes and a true third function. Top-n-tilt is definately on the list ASAP now. It's quite a pain not being able to adjust that stuff from the seat. And everything is so much heavier than the ford, I can't man handle it like I used to.
Quick question to you, as I know you have hydraulics experience: when I push the joystick past the float detents, I can hear the system go into relief and the loader creeps down ever so slowly. The lever does not lock in the float position. Could they have botched the remotes install? Any ideas?
Thanks.
   / Buying a used MX5100 - some questions. #72
Are the loader couplers fully seated and connected to the correct ports?
   / Buying a used MX5100 - some questions. #73
I like the second pic with the guard dog. Looks like he is serious business. :laughing:
   / Buying a used MX5100 - some questions. #74
Congrats, you have a very capable machine that should serve you well.
   / Buying a used MX5100 - some questions. #75
Thanks to all participants for this thread!:drink:
I'm replacing my Fordson and just pulled trigger on a 2012 MX5100 with 181hrs. I am also having the dealer add 3 remotes, it already had front 3rd function and filled rears. Now I have to wait for the remotes to be installed and shipping process to get it from PA to HI. I probably won't see it until late January '17.
   / Buying a used MX5100 - some questions. #76
Just curious, how much is the dealer charging for your 3 remotes and install?
   / Buying a used MX5100 - some questions. #77
   / Buying a used MX5100 - some questions. #78
Now don't rub it in! :D
Just wanna know how much I actually saved. My dealer never quoted me a price installed. And I didnt even price everything. I just inquired about the valves and when he started spewing out the prices, I didnt pursue the matter any farther, I had heard all I needed.
   / Buying a used MX5100 - some questions. #79
Just as a point of reference LD my dealer charges $1100 for the 3rd function hydraulic set up. Seems to be the going rate around here. I've not got the 2nd remote quoted from them. Should have had that put in when I got the tractor I guess.
   / Buying a used MX5100 - some questions. #80
The 3 remotes were $2,400 which included one float. I had read your thread on the DIY remotes and decided I needed the remotes on arrival and I'm just not clever enough to get the job done in short order ... but I was tempted.
I chose the MX over an '04 L5030 on the west coast with 354 Hrs primarily on age and extras. I got this one with the remotes, a 3rd function and loaded tires landed in Carson, CA for what the L5030 would have been with just the 3 remotes and no QA on the loader which is about what the OP said his would cost before the remotes. The only difference is the ding in the hood.
Superior 16' Bumper Pull Trailer (A57453)
Superior 16'...
8ft Teakwood Live Edge Slab Table (A57454)
8ft Teakwood Live...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
Tank Only (A59076)
Tank Only (A59076)
ARI-Hetra 15,000lbs Auto Lift (A56860)
ARI-Hetra...
