BX 2200 Cheap Cab
   / BX 2200 Cheap Cab #21
Can you give us a source to buy the golf cart cover? How do you get in and out? /forums/images/graemlins/confused.gif Thanks
   / BX 2200 Cheap Cab
Hi,
I got it from
http://www.northerntool.com/
Type in
Golf Cart Rain Cover and you will get this.
Deluxe Drivable Golf Cart Rain Cover. Best we've seen! Super clear vinyl cover fits over most golf cart rooftops to keep you dry. Zippers allow easy exit and entry. Or you can roll sides up and secure them with snap-straps. Rear zippers give you access to golf clubs. Easy on, easy off cover has adjustable hooked straps and buckles for customized fit. Storage bag.
Temporarily Backordered usually ships in 2 to 5 days
Ship Wt. 9.0 lbs
Item# 450502
Discount Price... $99.99
It has a zipper door on both sides to get in and out.
   / BX 2200 Cheap Cab
I have had several requests for addtional information so here it is hope it helps.
The plywood roof is 48 inches wide by 58 inches long ( front to back). If I was doing it again I would use 3/4 inch plywood, I do get some sagging when I get 8 inches of snow on the cap. You do have room to operate the FEL, attached is a picture inside of the cab.
   / BX 2200 Cheap Cab
The rear of the unit looks like this. I just lift the plastic to move the snowblower handle.
   / BX 2200 Cheap Cab
The rear bracket is held in place with some 1/4 inch bolts with double nuts to prevent them from coming off. I kinda used what I had in the spare nut and bolt bins. I left this bracket on during the summer because the rear light was connected to it. Since I have removed the rear light to the outside, I will remove the bracket in the summer. All the electric connections are on quick disconnects, so dewiring will be just a few minutes in the spring.
   / BX 2200 Cheap Cab
Last one, this is how the copper tubing, which is a 31 inches by 31 inches, connects to the tractor on the left side. A bolt and a large washer works well.
If you have any other questions, please let me know.
   / BX 2200 Cheap Cab #30
You should get your dollars worh out of it!
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
