BX 2200 LIFT ARM ADJUSTERS
   / BX 2200 LIFT ARM ADJUSTERS #11
Bill, sorry for the confusion. I thought the discussion was about the stabilizers, the gadgets that limit side-to-side play. My Ford has chains and turnbuckles (one is rusted fast), and the 7500 had rods with turnbuckles that I replaced with the telescoping parts..............chim
   / BX 2200 LIFT ARM ADJUSTERS #12
Chim,
Would you mind telling us the cost of the telescopic sway control parts? Do the sway arms on the 2710,2910 fit the 7500 and 2410? I don't like those turnbuckles either.
Thanks,
winchman
I called my Kubota dealer, and the price he is quoting for the B2710/2910 telescopic "adjusters" is approx. $60.00.
To clear up any confusion reguarding my original post, chim is correct in that I am descibing the side to side BX turnbuckle adjuster, that I wish to replace, not the telescopic lower link end.
I will be at the dealer next week. He has the B2910 & BX 2200, to swap the adjusters. I will follow up with another post with the details of this experiment.
WALT
   / BX 2200 LIFT ARM ADJUSTERS #14
Winchman, there was a 7500 and another tractor parked side by side, and I measured both to find the same parts would work on either one. Can't remember for sure if it was 2410, 2710 or what There may be a lot of Cat 1 parts that are common between models. The dealer quoted me $60 per side / $120 total, and offered credit for my unused turnbuckles.
As promised, here is the update to my initial post. I was at my dealer yesterday, and inquired about the interchangability of the telescopic adjusters for the turnbuckles.
We removed the tele. adjusters from a B2710, and sized them to a BX 2200. It was a close enough fit. My dealer (Leahy Equip., Holyoke Mass.) was kind enough to sell me the tele. adjusters from the B2710, saving me another trip.
The telescopic adjusters are sold as (1) flat bar & (1) receiver tube bar. The part #'s are: flat 6C070-65333 and receiver 6C070-65320. You need (1) each for each side, for a total of two flat bars & two receiver tube bars.
The cost was $13.65 each for a total of $54.60 + tax.
It would appear that the B7500 & B2410 could also use this modification.
This A.M. I took apart the turnbuckle assembly to mount the replacement telescopic adjusters.
The two modifications to the tele. adjusters are as follows:
1. Flat bar: A second hole (7/16") needs to be drilled behind the first hole, to accommidate the "U" pin that attaches to the front adjuster swing plate. Once drilled the "U" pin will fit into the bar end.
2. Receiver Bar: On the bar end that attaches to the lower lift arm, cut & remove approx. 1" of the side of the receiver tube. This allows the receiver bar to fit onto the metal tab on the lower lift arm, using the original pin to secure it. This is easily done with a 4 1/2" hand grinder with a cut off wheel.
Once I figured out how to make it work, it took about 30 minutes to complete the job, and reassemble the three point hitch. You also need a locking pin to set the side to side movement.
I then mounted my M40 rotary cutter, effortlessly adjusting the side to side play of the lower lift arms, vs. wrenching on the turn buckle adjusters of the BX2200.
Summarizing this long winded story, if you have a BX1800-2200, B7500 or B2410, you might consider this fix, speeding up your 3 point hook-up time, while reducing your aggrivation.
HAPPY TRACTORING:
WALT
   / BX 2200 LIFT ARM ADJUSTERS #16
Walt,thanks for the up-date.I'm going to print your post and order a set of these myself.
I hope the new set-up is easier on the wrists for you.
   / BX 2200 LIFT ARM ADJUSTERS #17
Walt
Can you post some pictures
Thanks
Sorry for the late reply, I had some internet connection problems. I do not yet have a digital camera.
When I am able to borrow one, I will post the pictures.
WALT
   / BX 2200 LIFT ARM ADJUSTERS #19
Walt, thanks for the info. It looks like I bought more pieces than you did. Just this week I stopped in at the dealership and settled up. I had returned the turnbuckle arrangement, and they gave me credit for them. Total out of pocket was a few cents under $50 for the whole works. I couldn't find the parts list so far, but the entire turnbuckle on each side went away. I got a new end for each flat bar and each receiver bar - 4 total, and a total of 6 pins with hairpins. On my B7500 the ends of the turnbuckles wouldn't work on the telescoping bars without mods. Nothing needed shortened.
While I was there, I mentioned I'd be back after I got a list together for stuff needed for the 50 hour maintenance. The counter guy said he had a list, and loaded me up w/ a gallon of motor oil, 3-1/2 gallons of hydraulic fluid and 4 different filters for an out-the-door price of $75.20. Glad the 'Bota doesn't need this every 50 hours.............chim
   / BX 2200 LIFT ARM ADJUSTERS #20
Does anyone have a picture of the telescopic adjusters on the 2710/2910 that is being retrofitted to the BX2200. They sound great but I just can't get them pictured in my head.
40' CONTAINER (A51244)
1999 International 4700 Dump Truck, VIN # 1HTSCAAN3XH660516 (A51572)
1999 International...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2019 Chevrolet Malibu Passenger Car, VIN # 1G1ZC5ST5KF136071 (A51572)
2019 Chevrolet...
