BX 2200 LIFT ARM ADJUSTERS
   / BX 2200 LIFT ARM ADJUSTERS #21
How's this? The retrofit application is on a B7500. From Walt's descirption, it may be different on a 2200. Yeah, it's dirty but I didn't have time to wash it tonight.....................chim
   / BX 2200 LIFT ARM ADJUSTERS #22
This setup looks a lot beefier than the turnbuckle on my 7500, but it doesn't look to be as infinitely adjustable as the turnbuckle?
I kind of like being able to snug the lower arms up tight when
I attach the box blade or brush hog.
Am I missing something here?
   / BX 2200 LIFT ARM ADJUSTERS #23
These adjust to limit sideway swing quite nicely. There are a couple of elongated holes for attaching something you choose to have some movement with. The photo doesn't show it, but the holes in the outer tube are evenly spaced, while the holes in the inner bar are unevenly spaced. They are almost infinitely adjustable. You don't need to move the lift arm very far at all to drop the pin in a different hole. Gotta go to work now, but I'll measure the amount of adjustment between holes tonight........chim
   / BX 2200 LIFT ARM ADJUSTERS #24
Great alteration Guys! Is the total cost on this about $55?
Those turnbuckles are too slow for my liking. I like making modifications to make my tractor more operator friendly. If that is the cost it is going to be added to the to do list.
winchman
   / BX 2200 LIFT ARM ADJUSTERS #25
That $50 was what it cost me to trade my brand-new factory turnbuckle setup for the telescoping ones. Without the unused turnbuckles to trade, it would have been $120..............chim
   / BX 2200 LIFT ARM ADJUSTERS #26
chim,
Thanks for the pictures - looks like a much easier hookup method than the turnbuckles.
   / BX 2200 LIFT ARM ADJUSTERS #27
RJS, sorry I got busy and forgot to measure till tonight. Like I said, the holes in the bar are unevenly spaced. What happens when you swing the lift arm slightly, different hole combos align. If you pull the pin and move the arm, there is another pair of holes that line up with about 1/8" of movement at the captive ball where the implement attaches. It's pretty easy to have the implement centered or off-center if you wish. There's one spot I mow where it is kinda nice to have excess deck to the right. It allows the deck to be close to the dropoff with the tractor on firmer ground...............chim
   / BX 2200 LIFT ARM ADJUSTERS #28
I know I'm late but, attached you will find a picture from the parts book of a B2710 showing the arms in question.
If your interested in obtaining your own parts book, go to http:www.tractorsmart.com and click on "Click to Enter" then "Check it Out" then I Don't know my part number" then "Follow this link to the parts page request form". Once there, fill out the form. You'll recieve your copy of the Parts Book in .pdf format.
Once you've recieved your parts book you can look at the picture and identify all the parts your want as well as obtaining the part numbers.
You can now go back to http:www.tractorsmart.com and order the parts you want.
And no, I don't work for nor am I associated with Tractorsmart. I just found the site to be very useful.
As for me, I've been testing various wheels in an attempt to offer a upgrade kit for the el-cheap-O anti-scalp wheels for the BX 54 and 60 inch mower decks. I've been testing various wheels and various bearing combinations. I should have something finalized withing the next 2 or 3 weeks.
DW
   / BX 2200 LIFT ARM ADJUSTERS #29
I attached it, but it didn't seem to work. I'll try again.
   / BX 2200 LIFT ARM ADJUSTERS #30
DannyWiliams,
Please let us know what you discover regarding the antiscalp wheel.
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
8ft Perforated Metal (A51573)
8ft Perforated...
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
